Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Hampshire Radio Discussion Forum
New Hampshire Radio Discussion Forum Forum for discussing Radio Information in the State of New Hampshire.
Old 08-25-2005, 10:05 AM
Default Scanner for Manchester,NH
Looking to buy a new scanner for Manchester, NH. Police, & Fire. From what info. I've gathered they use EDACS std. Please confirm. Looking at handheld or table top. Best bang for the Buck. I think I need Trunk Tracker. I currently have a BC80XLT, wanting to upgrade. Would BC246T do the job. What are my other options. Thanks, Bruce
Old 08-25-2005, 11:15 AM
crazyboy's Avatar
They use edacs. Here is the link to the Database
http://www.radioreference.com/module...=TRSDB&sid=172
The BC246T wil work. There are more options just look for a scanner that can trunktrack EDACS standard.
Old 08-25-2005, 5:18 PM
Thanks for the info. I'm new at this. Should I be looking at another brand. or differant model. I don't want to buy a scanner that is going to be obsolete shortly, or limit my use.
Old 08-26-2005, 8:47 AM
michael_m_rubino's Avatar
You need to consider a digital scanner like the new Uniden 396 or the Radio Shack PRO 96 for New Hampshire. Look at the Uniden and Radio Shack forums on this site to read up on them.
All of your sheriff departments in NH and the State Police are using conventional Digital radios. Most of the towns are going conventional digital too or are there already. Places like Nashua use trunked digital.
M.D.C. Police Photos - History of the Mass Metro Police (1893-1992)
http://home.comcast.net/~mmrubino/site/
PRO 433!
Old 08-26-2005, 8:32 PM
Junior08's Avatar
Most definitely!!!
You are surrounded by APCO-25 Digital in your location. For the available scanners capable of monitoring APCO, your choices are;
Uniden- BC 296 handheld/796 Base
Uniden- BC396T Handheld
GRE- Pro 96 Handheld/2096 Base
Those are the best available for APCO currently. Keep in mind any 800MHz rebanding to come along sometime next year, but it probably won't affect you too much in NH, there's not a lot in your area. EDACS will NOT be affected by rebanding. Search the forums here for rebanding information. Do your homework, and choose what suits YOU!
Mark,
www.scan-ne.net moderator
Old 08-28-2005, 5:53 AM
Smile scanner for Manchester NH
hi Bruce,
I live in Manchester and you really need to have a digital scanner like the ones mentioned.
Most towns including yours are using Apco-25,also the State Police.
Manchester is on a 800mhz Edacs system and sometimes they go coded which could be Provoice. If you like to check out a pro-96 or 2096 or the new Uniden- BC396T Handheld or need help getting started, let me know.
IC-R20,BC-780XLT,PRO-64, PRO-95,PRO-96,PR0-2096,BCD396T, BCD996T,IC-R2500,IC-2820H,PRO-197,PRO-106, many others over the yrs and too many antennas to list.
Old 08-28-2005, 10:17 AM
Default What's your preference
Thanks for all the helpful info. Now it's down to the final decision, Pro-96, Pro-2096, or BCD396T. I notice some on this forum have both the RS and Uniden. What's your preference on user friendly, and quality. This is a BIG purchase for me. I only want to do it once.
Old 12-30-2012, 8:26 PM
Default Questions on Manchester EDACS system.
Hello I have a few questions about manchesters Edacs system. What type of EDACS system is it: wide /narrow or Scat? And What should the site type be: wide or narrow? I'm doing this all by hand because I enjoy doing this stuff by hand. It's easier for me. but I'd enjoy some answers for these question if anyone wants to answer them.
Old 12-30-2012, 9:41 PM
morrisr3nd's Avatar
Default Other choices
You also have a few other choices. There are a few newer models of the ones already mentioned.
Radio Shack PRO-106 handheld PRO-197 base/mobile.
GRE 500/600. Same as above but with some different features
Radio Shack PRO-18 handheld. Only one capable of P25 phase II. TDMA
GRE PSR-800. Same as above.
Uniden BCD396XT. HANDHELD. BCD996XT. Mobile/Base.
Any of these would be excellent. I have one or more of some of these.
Hope this helps.
Call on his name "JESUS" and he will answer you.
Ronnie
Old 01-20-2013, 11:32 AM
I just programmed Manchester into my scanner.What scanner to you have? FYI Manchester uses wide/narrow.
Old 01-20-2013, 3:01 PM
I'm using a BCD996XT.
Old 01-20-2013, 6:56 PM
I have the Uniden BCD396xt which I believe is the portable version of the same scanner.
Let me know what you need and I will see if I can help you out. If you have the programming cable and Freescan, I can even send you my file.
Old 01-20-2013, 8:02 PM
I just need to know the site type. Is it wide or narrowed?
Old 01-21-2013, 8:16 AM
NYRHKY94's Avatar
BD70:
When I download the Manchester EDACS system from the Radio Reference database directly into my Uniden scanner using Proscan, it shows the system as "Wide". If you have the programming cable, you can try Proscan for 30-days free and simply import the entire Manchester system (including all talk groups) into your 996. You would be up & running in a matter of minutes. Just a thought....
PSR600/PSR500/PSR410/PRO106x2/PRO197x3/PRO2096/BCD996T/BC796D
BCT15X/BC898T/HP-1/BC210XLT
Feeds: http://www.radioreference.com/apps/account/?tab=la
Old 01-21-2013, 9:16 AM
Thanks the info. But now I have two questions. Should be on Id scan or I'd search if I'm only scanning certain types of groups? And since I live like 30 minutes away from Manchester, will it pick up just fine?
Old 01-21-2013, 10:00 AM
Lynch_Christopher's Avatar
Send a message via AIM to Lynch_Christopher Send a message via Skype™ to Lynch_Christopher
If you are only looking to scan certain talkgroups I would put it in ID Scan mode since since ID Scan only looks at the particular talkgroups that you programmed into the system. ID Search looks at all the talkgroups on the system.
Picking up the system will be dependent on the type of antenna that you use. The rubber duck antenna on my 396xT has trouble picking up the system from Nashua
Christopher Lynch
RadioReference.com Database Administrator for CT,MA,NH
Old 01-21-2013, 11:47 AM
You are probably going to need a good outside antenna to hear Manchester from that distance. I hadnt heard anything from there and I am 20 miles away.
I just bought a Scantenna ST2 and couldnt hear Manchester until I put it outside under my deck. I cant put it up at roof level as we live in a condo but I can only imagine how much more I could pick up if I could go higher.
Old 01-21-2013, 12:27 PM
NYRHKY94's Avatar
BD70:
It is "highly unlikely" you will be able to pick up Manchester at all from that distance with just an indoor antenna. Even with an outdoor antenna, Manchester is difficult to pick up due to the nature of that system. I live approximately 20 minutes away and have a Scantenna mounted at 35'. Manchester comes in but not that great to be honest with you. If you want to see what it sounds like, I host a feed here on the RR site:
Manchester Police and Fire Live Scanner Audio Feed
Old 01-21-2013, 3:28 PM
I concur with the above post. I can hear Manchester but its a little sporadic. The Scantenna ST2 is a nice antenna though.
Old 01-21-2013, 10:36 PM
Thanks guys. I appreciate the help and suggestions. One more thing though, I bet I won't pick up goffstown either right because that's an hour away from me?
