Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Hampshire Radio Discussion Forum
New Hampshire Radio Discussion Forum Forum for discussing Radio Information in the State of New Hampshire.
Old 12-25-2012, 11:50 AM
Default New freq
Does anyone in the Grafton Co New hampshire have any idea what the new Highway freq's are?
Old 12-25-2012, 3:26 PM
http://fjallfoss.fcc.gov/General_Men...limit_select=4
I couldnt find much-but you got this
Old 12-25-2012, 5:58 PM
ecps92's Avatar
Not sure what you mean by NEW??
Are you asking about NH DOT ? or your local [name the town]
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Old 12-26-2012, 7:43 AM
Default highway freq
Please excuse the lack of info new to this. Our highway dept in Lebanon NH just changed radios amonth ago. It would be in Grafton County, Lebanon NH.
Old 12-26-2012, 7:48 AM
ecps92's Avatar
What Freq and tone where you using ?
Bill N1KUG
Old 12-26-2012, 11:25 AM
Default Many Thanks
Thanks for the quick feedback, I guess I joined a great group. 1 more question if I may? I have a digital trunking scanner will I be able to pickup narrow band when my city goes to it??
Old 12-26-2012, 11:37 AM
You shoulnt-, but if your scanner has NFM included in the A.M/F.M dept, You may want to EDIT your freqs. I dont know about past Unidens, but my 396xt and bct15x have the N.F.M capability. The pro 106 has it-but wont program itself for N.F.M..That you do yourself. Everythings fine on my pro 84-no difference.
Old 12-27-2012, 11:15 AM
ecps92's Avatar
With agencies narrowbanding and some going TRBO it's hard to tell
without knowing the Original Frequency / tone you are listening to..
However, spending sometime on the FCC for just Lebanon Freqs there are many new licenses and pending applications to make changes in Lebanon
One of them is the Highway Department going TRBO [scanners cant listen to them directly] and adding a Repeaters...
Bill N1KUG
Old 12-27-2012, 4:18 PM
Default original freq
There freq use to be 155.100 w/o any tone.
Old 12-27-2012, 4:45 PM
ecps92's Avatar
according to the FCC 155.1000 is going to be the input to 159.2400
Unknown if you will hear much as it looks like both MotoTrbo and Analog
ULS License - Public Safety Pool, Conventional License - WPTV821 - Lebanon, City of
the existing license has not even been narrowbanded. So, it could be all off-line till the new Repeater is installed or they are using 159.2400 simplex
Bill N1KUG
Old 12-28-2012, 10:16 AM
Send a message via AIM to jmarcel66 Send a message via Yahoo to jmarcel66 Send a message via Skype™ to jmarcel66
Try keeping 155.100 in, but add 159.240. Their license with 155.100 (WPTV821) already on it has a pending modification to add 159.240 as a repeater.
The modification application indicates they are applying for both Analog and MotoTrbo Digital modes in narrowband. The analog will likely have a PL/DPL added. Unfortunately, if they go to the MotoTrbo, you scanner will not decode it without an invasive procedure to tap the audio.
John Marcel
K1FDD/WPXA902
Penacook, NH
Old 01-07-2013, 5:22 PM
Default Nac
I have 1 more ?? is it possible to program a RS Pro 197 to a freq and then have it scan for the NAC on just that freq? This is that 155.100 PW and I was told I need the NAC in order to hear it. Thanks in advance.
Old 01-07-2013, 5:46 PM
ecps92's Avatar
P25 aka NAC, is not the same as MotoTRBO, so No.
Unless you have identified they are going P25 and the license is wrong as it indicates MotoTrbo
Bill N1KUG
Old 01-17-2013, 7:59 AM
Default RS Pro 197
Can someone pls explain how to search freq 155.000-156.000 and continue to search, not just scan once. I want to scan between these 2 freqs till I cancel the search.
Tony
