Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum Forum for discussing Radio Information in the State of New Jersey.
Old 09-22-2009, 10:02 AM
Default Joint Base McGuire-Dix-Lakehurst
JBMDL officially comes on line October 1. Major changes to the radio systems are not expected to occur immediately with exception to Lakehurst, where all base support functions will go onto the 380 mhz TRS by the end of the year. The database has been updated with the TGs, it looks like it will be all encrypted. Their consolidated dispatch center will remain in place for now. McGuire and Dix will consolidate their public safety dispatch centers, rumor is that new TGs will be set up for security/police. On the fire side, the Dix TG's on the BurlCo TRS will be patched with the McGuire TG's on the Air Force system. Their hoping that Motorola comes out with their new multi band portables and mobiles that cover 380-512 mhz soon so they don't have to carry 2 radios. The 380 system for McGuire/Dix will be constructed sometime in 2010, a new tower was installed on Dix. An existing tower on the Dix ranges will also be changed to 380. The tower on McGuire will eventually come off line. Once this is all done it will be a 3 site SmartZone system to cover the Joint Base. One of the reasons for not doing work early is that most of the funding will not be available until after October 1.
Old 09-25-2009, 11:58 PM
Listen while you can another system going to full encryption soon.
Current radios 2 Xts-5000 vhf ,1 UHF Xts-5000, Xts-3000 uhf , uhf Xtl-5000 ,Motorola Urc-101,prc-113B, MBITR, and various scanners
Old 10-01-2009, 06:54 PM
The McGuire/Dix district police/security forces are now being dispatched from the Dix dispatch center, their TG's have been patched together. Look for fire to move over to McGuire dispatch by the end of the month.
Old 10-27-2009, 07:56 PM
Lakehurst PD is now using the TRS, TG 65010, which was identified earlier as the Command TG, this may change again. They are in the clear. Getting some hits on the Crash TG, that's encrypted.
Old 11-02-2009, 10:51 AM
Lakehurst PD now operating on the Police TG 65006 in the clear.
Old 11-02-2009, 03:13 PM
elias1988's Avatar
Send a message via AIM to elias1988 Send a message via Yahoo to elias1988
I have Pro96Com up and running on the system,currently theres 5 radios affililated to the police talkgroup,IDs are in 10xx range.I've picked up 2 new talkgroups that are in the clear,65020 and 65023 radios in the 10xx range have affililated to 65023.IDs in the 30xx range have affiliated to 65020.
Scanners/Fire Pager used: Pro-2096(Live feed),Pro-89(Retired),Pro-2043(moved to Station 44)Pro-96,Pro-106,Minitor V
BNN Dispatcher NJS-443 covering incidents for Ocean County,NJ
Old 11-02-2009, 04:54 PM
elias1988's Avatar
2 new talkgroups,65007 and 65021.ID in 30xx range affililated to both along with Command and Fire talkgroups.
Old 11-03-2009, 11:28 AM
TG 65020 is patched to the VHF fire repeater.
Old 11-03-2009, 11:39 AM
elias1988's Avatar
Ok,another new one popped up on my end,65015,looks like a police radio affilated to it.
Old 11-05-2009, 07:20 PM
elias1988's Avatar
2 new talkgroups on my end, 1 and 65013. a radio in the 2xx range affiliated to the public works talkgroup and then to 65013 a few seconds later.it appears a fire radio affiliated to 1.
