Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum Forum for discussing Radio Information in the State of New Jersey.
Old 11-04-2009, 04:31 PM
r60 r60 is offline
Default Need Two Tone 453.150 Union County Plz
Hey there all.
Anyone have the tone pair for paging Union County Mutual Aid?
Old 11-05-2009, 06:12 PM
Just speculation, however it is eerily close to Bergenfield, NJ's FD general tones... A 569.1/B 600.9... Again, just speculation, but you may wanna give that a shot.
Chris Saraceno
www.saracenophotography.exposuremanager.com
Old 11-07-2009, 02:35 PM
r60 r60 is offline
Default The two tone combo has been found.
MFR465 you have good ears.Close.
Thanks to Audacity (freeware) with the plugins I was able to
figure the two tone combo out with out with ease.
Union County Fire Mutual Aid Tones are
575hz 600hz
Time to load up F2 in my Minitor V with silent scan.
Old 11-07-2009, 09:08 PM
Alarmguy's Avatar
Send a message via AIM to Alarmguy
The two tones you posted are not valid tone sets. Chris is probably right on the money. The two tone sets he gave you are valid Quick call 2 tone sets. Your sets neither fit into either Quick call 2 or Plectron tones or any other manufacturer. Most agencies use either Quick call 2 tone sets or Plectron tone sets. Programs like audacity are usually a few hertz off. Even the BCD996XT is a couple of hertz off.
Old 11-07-2009, 11:28 PM
Tech792's Avatar
A few hertz off shouldn't matter. I've gone up to 10 hz off on some pagers and still had reliable decoding.
Old 11-08-2009, 01:27 PM
Alarmguy's Avatar
True. I had a similar situation with tones being a few hertz off. A town nearby uses plectron tones of 1910.0 and 910.0, I had originally used 1930.2 and 903.2 in my TK2180 and it always activated. However it would never trip in my old BCD996T in fire tone out mode. I upgraded to a 996XT which has tone reading capabilities and it showed 1899.0 and 909.0 as the tones. I programmed 1910.0 and 910.0 and the 996 now trips and the TK2180 works fine with the correct tones.
Old 11-10-2009, 08:29 AM
r60 r60 is offline
Default Th exact tones are
Motorola Tone pairs Tone A 569.1 Tone B 600.9
These are Tone numbers 120 & 121.
Thanks to all and especially MFR465 for the initial response.
Regards
Unread Today, 06:56 AM
Chauffeur6's Avatar
Just to have a little fun with this...the 575.0 you initially measured using Audacity is very close to GE 577.5 "G05". The closest GE tones to 600.0 are 592.5 "G06" and 607.5 "G07", making it likely that it is indeed Motorola 600.9 "121". It's entirely possible that they are using a mixture of the tone plans, GE and Motorola QCII. You should see some of the bastardized tone combinations used in Rockland and Orange, it would make your head spin! Mixtures of Motorola QCI and QCII, Plectron, GE, Federal, Reach, Bramco and even a few completely custom tones all mixed together, sometimes in the same two-tone sequence, with no rhyme or reason.
While I agree with Alarmguy that Audacity is usually off by a little bit, it may've been closer than you think in this case. I don't think it would nail the 600.9 second tone almost exact, but be off by almost 6 Hz for the first tone. The tones are too close together for that much variation between them. Of course, a lot of factors come into play when measuring them in Audacity, not the least of which is the quality and format of the recording you're measuring, as well as what settings you're using in Audacity to measure them. The PL/DPL can also throw the tones off a bit.
