Hi Daedalus, this is a perfectly fine place to ask your question.
The file you uploaded has the system configured as Type 1. In reality it should be set up as Type 2; once upon a time the state's systems were Type 1, then hybrids, but they are Type 2 now.
In Win96, on the right side, you see the list of talkgroups in the selected ID List. Above it are the Fleet Map codes. Change all these codes to S00, and you'll see the hyphen disappear from the TGID codes below.
You have just changed the system programming over to Type 2; briefly scan in "Open" mode to ensure all is working properly. If it is, you should go back and reprogram the updated Type 2 TGIDs (see the database on this site) into the memory, so that you see the correct text tags and are able to use the ID lists.
FYI, you have programmed in most or all of the Troop B frequencies. This won't really hurt anything, but it is only necessary to program in the four frequencies marked in red for the Pro-96/2096 to properly trunk the system. If you wish to program them all in, I'd suggest you put the four control channel frequencies in first (before the others) because it will slightly increase your scanning speed.
Good luck,
Jim
