Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum - Forum for discussing Radio Information in the State of New Jersey.
  #61 (permalink)
Old 04-04-2014, 6:52 AM
W2SJW's Avatar
Senior Member
Originally Posted by KC2ZHY View Post
... and T should be reserved for TDMA-Only.
100% agree.
Scott
NJ & PA DB Admin | NJ Forum Moderator
My BCDx36 Favorite Lists
  #62 (permalink)
Old 04-04-2014, 8:33 AM
DSC45's Avatar
I also agree.
  #63 (permalink)
Old 04-04-2014, 9:11 AM
W2GLD's Avatar
I agree as well; however, that what it was initially designed for... If you however over that field, you will see a description of what each designator is... I just entered the data in accordance with the policies set forth by the RadioReference Admin team. For what it's worth, generally in a Phase II system, including the NJPSIC system, ALL talkgroups are TDMA capable and should be entered into the database as such; this way the newer scanners will already be setup to track both timeslots if/when they make the final conversion.
Just my two cents, but again, I'm not living in New Jersey anymore, so whatever you guys decide... In the meantime, I will simply follow the policies established.
Regards,
Jerry
  #64 (permalink)
Old 07-16-2014, 4:36 AM
r60 r60 is offline
Default DB Update Montgomery DPW TG 735
Montgomery DPW on 700 P25 yesterday TG735 Digital
