Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum Forum for discussing Radio Information in the State of New Jersey.
Old 10-23-2012, 8:02 AM
Send a message via AIM to jcityfire
Default NJ Forest Fire service
Does anyone know what frequencies the Forest Fire Service would use when they work brush fires in the Meadowlands of Bergen County?
Old 10-23-2012, 8:10 AM
GM GM is offline
Smile Nj ffs
Program all of these in to your radio:
Department of Environmental Protection Scanner Frequencies and Radio Frequency Reference
Depending on the situation, they use multiple channels at different times/incidents. You may want to keep the CTCSS tone (PL) off, since they use different tones on the same frequency for different events.
Old 10-23-2012, 9:01 AM
DJ88's Avatar
Send a message via AIM to DJ88
The Forest Fire Service Radio Communications Plan was updated in July of 2010 and it looks like the RR Database doesn't show this update: You can find it here:
Department of Environmental Protection (NJ) - The RadioReference Wiki
See New Jersey Forest Fire Service Radio Communications Plan.
I believe Division B handles the area you're referring to. It's either Division B or C. Maybe someone can clarify this.
My Toys:
Uniden BCT15X | Uniden BCD996T | Uniden BCD396T
Uniden BC785D | Bearcat 210XLT
Old 10-23-2012, 3:38 PM
EJM EJM is offline
Division A covers Northern NJ.
Old 10-23-2012, 5:46 PM
DJ88's Avatar
Thanks. I had them bass akwards. I thought B was north and A was South. Probably thinking of the NJSP Troops.
My Toys:
Old 10-23-2012, 6:58 PM
Tech792's Avatar
That meadowlands area is a "secondary response area" for Div A. (Not in the primary response area). Its not an automatic response. Usually will only go in if requested. Otherwise, the local towns will normally handle it.
Old 10-24-2012, 8:45 AM
Lately the been sending one person out to the bigger brush fires to offer assistance. They did work a fire in Carlstadt with a few crews earlier this year.
Old 10-24-2012, 3:57 PM
jaymatt1978's Avatar
Send a message via AIM to jaymatt1978 Send a message via Yahoo to jaymatt1978
I wish the person running the feed for South Bergen would add some of the NJFF frequencies
Justin Mattes,KC2GIK
www.bergenscanner.com
www.justinmattes.com
kc2gik@justinmattes.com
Old 10-25-2012, 8:32 AM
Tech792's Avatar
Here is a map showing "primary" and "secondary" response areas.
Our Team Site
Old 05-04-2013, 9:27 PM
Post
I have a dual band radio with RX frequency, TX fre.,CTC/DCS Dec, CTC/Dcs Enc. I have all the forest fire frequencies programed but i only hear half of the talk. ive tried alot of the channels but get nothing can someone please help me out!!!
Old 05-05-2013, 11:18 AM
trsundstrom's Avatar
Mentor
Wirelessly posted (Moto Droid Bionic: Mozilla/5.0 (Linux; U; Android 4.0.4; en-us; DROID BIONIC Build/6.7.2-223_DBN_M4-23) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Runnenfisch, not really enough information to answer your question properly: radio, antenna, terrain, surroundings, etc. Assuming you are within the area of the state served by the NJFFS as linked above, I would suggest you remove any CTCSS that may be programmed into the scanner. Here in DivB I find multiple tones are used on any given frequency. The RRdb is up to date; it is just difficult to detail all the tone variations. HTH.
Tom - W2XQ - w2xq.com
RS PRO-2041 & PRO-106
Old 05-06-2013, 10:01 PM
The radio is a Wouxun KG-UV6X with a stock antenna and i live in Roxbury so kind of hilly but nothing crazy. im going to try and turn off the CTCSS and see how that works. not necessary with the FFS but you need to program a specific CTCSS to talk correct ?
THanks for all your help
Old 05-10-2013, 7:53 PM
Mentor
Wirelessly posted (Moto Droid Bionic: Mozilla/5.0 (Linux; U; Android 4.1.2; en-us; DROID BIONIC Build/9.8.2O-72_VZW-22) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
You would need CTCSS to transmit if the repeater requires it. I don't know anything about your radio; is it FCC type-accepted? I don't follow the RR threads on the manufacturer. My comments on removing the FFS CTCSS tones were intended for the GRE/Uniden scanners. I load the data from the RRdb, but remove the tones before saving the file. HTH.
