| New Jersey Radio Discussion Forum Forum for discussing Radio Information in the State of New Jersey. |
12-12-2012, 5:24 PM
Morris Cty MIRS Sites
Hey Gang,
I was wondering if anyone knew the locations of the Sites? Like towns or general area. it's easier for programming scanners. Thanks!
Eric
12-12-2012, 6:41 PM
Moderator
North Simulcast Zone - tower sites at Kinnelon, Jefferson and Boonton
South Simulcast Zone - tower sites at Randolph, Chester, Morristown, Dover and Netcong
There are also intellirepeater sites in Washington Twp (Southwest IR) and Long Hill Twp (Southeast IR).
12-12-2012, 10:52 PM
Ty Very much!! Any chance we can get this added into the database?
12-13-2012, 12:47 AM
It's there.
http://www.radioreference.com/apps/db/?sid=1319
Zone Transmitter Site Locations:
Zone 1 - Chester, Randolph, Dover, Netcong, & Morristown
Zone 2 - Boonton, Kinnelon, & Jefferson
Zone 3 - Washington Twp.
Zone 4 - Chatham
The frequencies are broken out by site too.
Mt. Olive (Morris County), NJ
Bearcat IV, AR1000, AR8200 MK1 EU (Non-Blocked), BCD396T & BCD396XT
12-13-2012, 12:56 AM
UGH!! i looked right past it.. Sorry.. Been long few days!! Ty for pointing it out!! I had the North in my Scanner being in Hopatcong and signal wasn't that great i changed to the South freqs and its full scale..
12-13-2012, 6:11 AM
MIRS Sites
New site coming online this month at the Riker Hill site in Livingston/West Orange.
12-15-2012, 1:07 AM
In addition to Riker Hill, I'm told the 7.x upgrade will be completed this month, with a switch over on Dec. 19th. Riker Hill's site will be a godsent to those in the Madison-Chatham-Long Hill area that is PLAGUED with reception issues.
12-15-2012, 1:17 AM
Any idea when the system is going to be upgraded to 9600 baud?
Once that happens my MIRS feed is gone from RR cause i only have a BC785D
Eric
12-15-2012, 7:00 AM
Anyone know if this will be highly directional antenna(s) pointed back into Morris? I've long wondered why County systems focused on towers inside the county particularly when they meet the next county in a valley like south and eastern Morris borders Somerset, Union, and Essex
12-15-2012, 10:56 AM
Moderator
Long Hill already has an IR site. But yes, this site will help. Does anyone know if it is going to be part of the North or South Simulcast?
BTW, how long is Motorola supporting 7.x?
12-15-2012, 12:27 PM
The system will be one large zone after the P25 conversion. There will be no more simulcast sites & IR's.
It should make programming & monitoring the system much more easy.
12-15-2012, 5:32 PM
From what I was told by one of the system admins, yes. Directional antennas pointed in a downwards angle towards their intended reception area. This is a result of complying with regulations that are attempting to confine these emissions to the Morris County area and prevent them from causing interference to other agencies using the same frequencies in NY.
Also, that Long Hill IR still left coverage gaps in certain areas of the township, and also didn't alleviate the reception issues for Chatham Twp on the River Rd side of the ridge.
12-16-2012, 3:08 PM
It will be 9600 soon.........
12-16-2012, 9:18 PM
Moderator
Hmmm. If I'm not mistaken, doesn't Bergen run a 9600 baud Astro P25 system with two simulcast zones...one classified as "Mahwah" and the other "Alpine?" Morris County is not doing the same? If it is one large system, then they would have to add ALL the frequencies to ALL sites which would be a huge cost in infrastructure upgrades. And there would be only one active control channel...
12-16-2012, 9:31 PM
It will be one zone. There are significant performance benefits in going to a one zone system. Previously with Astro narrow pulse it was not possible to do one zone due to the maximum distance between site limitation. With linear simulcast that limitation is no longer a factor.
The new system is adding three additional sites.
12-16-2012, 10:15 PM
RocketNJ,
First, welcome back to the east coast. Second, will those three additional sites, including Riker Hill, go up on the 19th as well?
12-16-2012, 10:26 PM
No, the new master site comes on first which should not impact coverage or scanning. Once that is done then the cutover to 9600 will be scheduled
12-18-2012, 9:28 PM
Moderator
I see the new site in Livingston and what looks like an additional site in Washington Township on West Springtown Road below. What is the other one? I checked the ULS and found the following...
"South Simulcast"
JAMES ANDREWS PARK, WEST HANOVER AVE RANDOLPH, NJ
2.5 MI SE OF STANHOPE NETCONG, NJ
FOX HILL DRIVE DOVER, NJ
COURT STREET MORRISTOWN, NJ
300 MAIN STREET CHESTER, NJ
"North Simulcast"
ROSS DRIVE BOONTON, NJ
WELDON ROAD MILTON, JEFFERSON, NJ
PATRICIA DRIVE KINNELON, NJ
"Southeast IR"
LONG HILL ROAD LONG HILL, NJ
"Southwest IR"
HIGH RIDGE ROAD LONG VALLEY, NJ
New sites??
180 WEST SPRINGTOWN ROAD LONG VALLEY, NJ
284 BEAUFORT AVENUE LIVINGSTON, NJ ESSEX County
And a little birdie that told me Rockaway Township....
12-19-2012, 4:45 AM
Yep, you are correct. northern Rockaway Twp. The new system will be 13 sites, one zone.
12-19-2012, 7:36 PM
Moderator
RocketNJ,
With linear simulcast, do all the sites utilize the same control channel? Also, do all the sites transmit on the same frequency when a radio keys on a particular talkgroup, or does the controller not key a site if no radios are affiliated to that specific site?
Sorry to hijack with a technical question, just trying to clarify for a guy in a tie.
