Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum Forum for discussing Radio Information in the State of New Jersey.
Old 12-24-2012, 2:37 PM
r60 r60 is offline
Default 153.950 Unlicensed Fire Operation..Franklin?
I wonder who would be so reckless using 153.950 as a repeater output.
I have been hearing a repeater crossband P25 trunked system.
Sounds like fire operations in Franklin area. I could be wrong.
This a a protected mobile only channel, I see no FB2 licenses.
Other users like Red Bank use this as the input to the repeater. That signal
is going to block Red Bank Fire's portables.
I see many FCC violations on this operation and potential litigation if someone gets hurt.
Old 12-24-2012, 2:46 PM
Chauffeur6's Avatar
DB Admin
According to the database, Franklin is using 153.950 as the input to 166.250, and they are licensed for that operation under KSZ507.
Somerset County, New Jersey (NJ) Scanner Frequencies and Radio Frequency Reference
KSZ507 (FRANKLIN TOWNSHIP FIRE DISTRICT 3) FCC Callsign Details
Are you sure you're not hearing the input? Did you monitor 166.250 to compare what you're hearing? Try attenuating the signal to verify input vs output?
Old 12-24-2012, 2:57 PM
Close enough to be hearing a mobile? Maybe some kind of skip?
Old 12-24-2012, 3:49 PM
r60 r60 is offline
Default output
No, it is an output.
Huge signal, xband link to P25.
DPL 025
Old 12-24-2012, 3:56 PM
That's the channel (frequency and DPL) which was used for input to the District 3 repeater (166.250/192.8). I used to hear their District 3 ops talkgroup multicast over 166.250 but recently I noticed I wasn't getting it there anymore and was wondering where it went.
I guess something happened, deliberately or unintentionally, and things got reversed.
Jim
Old 12-24-2012, 8:45 PM
Tech792's Avatar
You'd be surprised how many repeaters and base stations operate on mobile only channels. And some are legally licensed.
Old 12-24-2012, 10:58 PM
W2SJW's Avatar
Senior Member
All Franklin fire districts have simulcasts from the trunk system to their old fireground ops channels - I'm just as confused as you are as to why they decided to run it on the input of the old District #3 repeater (where as District #1 still uses 154.160).
Scott
NJ & PA Database Admin
My FreeScan File
Old 12-26-2012, 10:45 AM
r60 r60 is offline
My conjecture is as follows:
Clearly they are using 154.310 for paging out calls.
So if you have a pager, you will be limited by it’s bandwidth.
One pager will not do 154.310/166.250 (so they can listen to the trunking system).
So therefore responders had to carry a portable or two pagers.
By changing to 166.250 to 153.950 one pager can do both 153.950/154.310.
But without the proper license and coordination they are screwing everyone who uses that 153.950 as a repeater input.
Someone could get hurt IMHO.
Old 12-26-2012, 11:29 AM
902's Avatar
902 902 is offline
There is a loophole in the Rules and Regulations which allows coordinators to assign "mobile only" frequencies as base stations and repeater outputs. When this is done, the system becomes secondary to mobile stations. Sometimes (but not all) these terms are placed on the license as "special conditions," although the secondary status remains whether that's on the license or not. If they're on the license, they're "legal."
That said, since there is no apparent repeater output on that frequency, you may want to think outside of the box: Many years ago (70s?) there was an interference complaint in North Hudson where they were hearing Bayonne. Bayonne operated on 166.25 at the time. North Hudson (I forget if it was West New York or Union City that complained - it was way before "Fire Control" or NHRFR) was hearing it on 170.15. Impossible? Not when the Philadelphia fire EMS channel was toggled into carrier squelch somehow and was retransmitting Bayonne from 70 miles away. A similar story is outlined in Ed Singer's Land Mobile Radio Systems book involving a problem with FDNY's VHF system (I believe it was between Brooklyn and somewhere in eastern Pennsylvania). And, through most of the 70s (and probably way before), Newark FD (154.13) was operating in carrier squelch and retransmitting Northampton County, PA (154.34) and their QuikCall I ("Squad 51" tones) alerting.
When I worked in the Midwest, I could hear dozens of repeaters keying in a big loop when the band opened up.
Old 12-27-2012, 4:07 PM
Somebody noticed, they're back on 166.2500.
Old 12-28-2012, 10:35 AM
r60 r60 is offline
Default Yep
That was the intent,to get it noticed right here.
This forum is a much better format than other options.
The fact that email contacts are part of the FCC database sure
makes it easy to send the link to this thread link as well.
Gee, I wonder if that happened?
