Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum - Forum for discussing Radio Information in the State of New Jersey.
  #201 (permalink)
Old 03-31-2013, 7:30 AM
There will be one more control channel being turned on in the future. You do not want to add it to the scanner now as it is in use on the old system.
  #202 (permalink)
Old 03-31-2013, 7:36 AM
Signal-Zero's Avatar
What Public Safety talk groups are still active on the "old" system? I'm fairly certain all PDs made the switch, but it sounds like only a few Fire/EMS agencies have come over (like those on FIRE RESP 1).
"We celebrate our independence from the Government, not our dependence on it."
  #203 (permalink)
Old 03-31-2013, 1:54 PM
All muni PD, Fire, and EMS made the move. and County LE moved as well.
  #204 (permalink)
Old 03-31-2013, 2:36 PM
W2SJW's Avatar
Senior Member
Just to confirm - if all you are interested in monitoring is public safety, it's probably safe to delete the Type-II system from my scanner, correct?
Scott
NJ & PA DB Admin | NJ Forum Moderator
My Sentinel Favorite Lists
  #205 (permalink)
Old 04-07-2013, 6:07 PM
Originally Posted by Chauffeur6 View Post
1793 - Operations 1
1794 - Operations 2
1795 - Operations 3
1796 - Operations 4
1797 - Operations 5
1798 - Operations 6
1799 - Operations 7
1800 - Operations 8
1801 - Operations 9
1808 - Operations 10
1809 - Operations 11
1810 - Operations 12
1811 - Operations 13
1812 - Operations 14
1813 - Operations 15
1814 - Operations 16
1815 - Operations 17
1816 - Operations 18
1817 - Operations 19
1824 - Operations 20
1825 - Operations 21
1826 - Operations 22
1827 - Operations 23
1828 - Operations 24
1829 - Operations 25
I noticed these were not in the DB. Have they been confirmed? If so, is there a layout as to what each one is for (such as the ole MIFD, MIPD, MIEM and MIOP channels)?
  #206 (permalink)
Old 04-07-2013, 8:45 PM
I can not confirm the TGID's are correct but that is the correct format. As far as I understand they will be shared by both police, fire and EMS and assigned by dispatch for use as needed.
  #207 (permalink)
Old 04-08-2013, 1:04 PM
Sybex7254's Avatar
I cannot confirm if the entire list is 100% correct but can confirm hearing a lot of activity on OPS-10 during St. Patrick's Day parade in Morristown.
I concur with the previous post, they seem to be assigned by the county communications dispatchers as needed and do not have predefined allocations/usages.
BCD536HP | BCD436HP | BCD996XT | BC-RH96 | HP-1 |
  #208 (permalink)
Old 04-08-2013, 1:27 PM
Disp419's Avatar
Is the County road department on the new system or did they remain on the old system.
Uniden HomePatrol
BC796D With digital card
BC785D With digital card
BC250D With digital card
  #209 (permalink)
Old 04-08-2013, 1:55 PM
The Ops talkgroup ID's are confirmed based on my logging and listening, I'm just not sure if there is a more specific usage than "Operations #" for each one.
  #210 (permalink)
Old 04-08-2013, 2:03 PM
Sybex7254's Avatar
Believe ONLY Public Safety has moved. I am pretty sure MAPS, MUA and CG1 & CG2 are still on the old system.
However I'm hearing activity on OPS-1 now and MIFD-1 on the old system. May be worth keeping the old one in until it's officially depreciated since we don't have a 1:1 talkgroup matchup.
  #211 (permalink)
Old 04-08-2013, 4:31 PM
Non-LE are moving starting this morning.
  #212 (permalink)
Old 04-08-2013, 4:33 PM
To answer the OPs question, yes they are dynamically assigned by the Comm Center on an as needed basis. Some are patched during the cutover.
  #213 (permalink)
Old 04-08-2013, 9:09 PM
Thanks RocketNJ. I was inquiring since there are 25 "Ops" channels and usually 16 channels per zone in a portable. I didn't know if maybe FD had 1 through 16 assigned, etc. I heard MAC using 1 and St. Pattys in MOTown on 10, thought I'd throw it out there.
  #214 (permalink)
Old 04-08-2013, 9:14 PM
I also heard (well, not really) ENC on TG 270. Two Roxbury PD portables back and forth the other day for quite some time. I know it's been posted here previously...anyone have an alias for it?
Chauffeur6...anyone other than PD radios affiliate to that TG and any comms other than ENC? I can't run Unitrunker from here and just want some confirmation before I tag it "LE SECURE" and lock it out.
  #215 (permalink)
Old 04-08-2013, 11:14 PM
The two encrypted talkgroups with the most activity on them are 270 (10E) and 846 (34E)...note the clever use of the HEX ID. I haven't been tracking the system full-time for the past two weeks or so, but I just opened up two separate history windows for each encrypted talkgroup. I'll get back to you on what IDs I'm seeing for each by the end of the week.
  #216 (permalink)
Old 04-09-2013, 3:08 AM
Here's the list of RID's that have made calls on each of the two active encrypted TG's. This might give you some idea what each TG is used for. Note that they were using 270 as the test TG when the system first came online, so that might be skewed a bit. I've cleared the hits for both groups and I'll log for the next couple of days so you have some clean results.
TG 270
43015
43062
50242
50543
51345
51840
51940
51945
52340
52345
52346
52643
52941
52945
53243
53640
53641
53643
53645
53840
53845
TG 846
42335
42338
43138
43139
43140
43146
43153
43155
43161
  #217 (permalink)
Old 04-09-2013, 8:13 AM
nosoup4u's Avatar
Sounds like the county buses have moved over onto TG 770.
John - KC2KZZ
http://www.warrenskywarn.org
SDS100, BCD536HP, BCD436HP, Home Patrol-2 , BC125AT and other old crap.
@kc2kzz - My Twitter feed. @WCAlerts - Warren County Fire/EMS alerts
  #218 (permalink)
Old 04-09-2013, 4:14 PM
Yes have been hearing MAPS on 770 all day.
North Jersey BC 996XT | BC 996P2 | 3 X BCT 15X | WHISTLER TRX - 1 | WHISTLER TRX - 2 | BC 346XT | BC 780XLT | 3 X BC 355 | RS Pro 405 | Pro 135 | PRO 2050
  #219 (permalink)
Old 04-10-2013, 6:01 PM
A few more RID's on the ENC TG's from yesterday and today:
TG 270
53640
53641
53643
53645
TG 286
43062
43063
TG 846
43159
  #220 (permalink)
Old 04-11-2013, 8:14 AM
nosoup4u's Avatar
809 sounds like it may be Sheriff Ch. 3. Hearing units sign and off at several courthouses.
John - KC2KZZ
