Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum Forum for discussing Radio Information in the State of New Jersey.
Old 01-01-2013, 2:41 PM
r60 r60 is offline
Default Hunterdon 155.025 License
Any Hunterdon experts know 155.025 pl 97.4?
I have been listening to 45 46 91 cars on stops in these towns streets.
They call Hunterdon.
I checked wiki here and the DB. Also checked this forum.
No luck on an FCC license as well.
Can we confirm and make this a new DB submission or am
I overlooking something?
Nice signal.
Old 01-01-2013, 2:50 PM
Chauffeur6's Avatar
DB Admin
The correct frequency is 155.0175, not 155.025, and it's already in the DB
155.0175 (97.4 PL) - WNMK960 - Hunt PD 5 C - Police Dispatch Central
Old 01-01-2013, 4:02 PM
r60 r60 is offline
Default thanks
Happy New Year
Old 01-01-2013, 4:05 PM
DJ88's Avatar
Send a message via AIM to DJ88
It's got something to do with the step size. Your scanner rounds off (for lack of a better term) 155.0175 to 155.0250. I don't understand enough about it to explain it to you.
My Toys:
Uniden BCT15X | Uniden BCD996T | Uniden BCD396T
Uniden BC785D | Bearcat 210XLT
Old 01-01-2013, 4:16 PM
Chauffeur6's Avatar
DB Admin
Originally Posted by r60 View Post
Happy New Year
Same to you.
DJ is correct, this is one of the VHF frequencies that falls on a 7.5 kHz step, not 5 kHz. Same goes for any VHF frequency with four digits to the right of the decimal point, it's a product of narrowbanding.
I believe you have a 996XT, correct? Make sure the band default for VHF is set to NFM 7.5 kHz.
Menu > Settings > Band Defaults > 150.8
Press E, set Modulation to NFM, press E, set Step to 7.5 kHz, press E, press L/O to exit the menu
If you have custom searches programmed in the VHF range, make sure you have them set for NFM/7.5 kHz as well.
Old 01-01-2013, 7:51 PM
kb2vxa's Avatar
Eh, don't forget to program the right frequency, it won't change by itself. You don't say what you have but if it's an older type (pre narrow) it will round off to the next higher standard frequency but is wide enough to receive the splinter frequency (4 digit) below it.
