Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum Forum for discussing Radio Information in the State of New Jersey.
Old 02-01-2013, 11:17 PM
maalox's Avatar
Send a message via Yahoo to maalox
Default port newark container terminal
hello does anyone monitor the port newark container terminal i would like to listen to them but i do not here anything on the there freqs thanks in advance.
Old 02-02-2013, 9:11 AM
e911god's Avatar
Moderator
They are using a UHF LTR system, so make sure you have your scanner programmed accordingly. The system doesn't put out much power, but I hear them fine over by EWR.
WPUD811 PNCT/LTR
1 452.0375
3 452.1625
5 452.3125
7 452.4125
9 461.0875
11 461.1875
13 451.7625
15 451.0625
17 461.2625
19 464.2625
Moderator - New York and New Jersey Forums
Forum Rules and Guidelines
Old 02-02-2013, 9:18 AM
maalox's Avatar
thank you. i try searching for this system on the hp1 i cant seem to find it.
Old 02-02-2013, 6:54 PM
e911god's Avatar
Moderator
If you download direct from RadioReference, look under Essex County.
Old 02-02-2013, 8:08 PM
Chauffeur6's Avatar
DB Admin
For some reason, that system is not in the Sentinel/HP-1 database. Probably because none of the talkgroup ID's are valid. Sentinel/HP-1 is very picky when it comes to what trunked systems are included in the database. Trunked systems with no talkgroups listed, or with invalid talkgroup ID's, are rejected during the import from RR.
Specifically, the 00 is not valid in the format x-00-xxx. That needs to be a number between 01 and 19 to indicate which repeater/LCN the talkgroup is homed to.
I'm going to submit corrections for the talkgroups based on what I'm seeing listed as the home repeaters, but someone really ought to verify the changes once they are made.
Old 02-02-2013, 8:29 PM
maalox's Avatar
i thought so thank you Chauffeur6
Old 02-02-2013, 8:31 PM
Chauffeur6's Avatar
DB Admin
Hopefully one of the admins will make the changes tonight or tomorrow morning so it'll make it in time for Monday's HP-1 update.
Old 02-02-2013, 9:58 PM
e911god's Avatar
Moderator
Correction to my previous post...15 and 19 are correct in the DB.
15 461.0625
19 464.5625
This is what I have for talkgroups
0-19-015 CRANE 1
0-17-016 CRANE 2
0-15-017 CRANE 3
0-11-019 CRANE 5
0-03-002 LOCATIONS
0-07-021 CRANE 7
0-05-022 CRANE 8
0-09-020 CRANE 6
0-13-018 CRANE 4
0-03-023 CRANE 9
0-03-011 GRID
0-03-010 DATA
0-03-001 CONTROL ROOM
0-05-025 CUSTOMS
0-05-003 SECURITY
0-01-006
0-05-013 MANAGEMENT
0-07-004 CRANES
0-07-014 RAILROAD
0-03-008 REEFER
0-05-026
0-07-009 MAINTENANCE
0-07-005 POWER SHOP
0-05-007 YARD FOREMAN
0-03-012 ALLOCATIONS
Old 02-02-2013, 10:01 PM
e911god's Avatar
Moderator
Also keep in mind Port Newark Container Terminal (PNCT) is one of many terminals at Port Newark/Elizabeth. The other two main terminals are Maher and APM Terminals. Maher uses Nextel. APM uses UHF as follows which needs input in the DB as well:
1 APM MARINE R 451.4625 AU CTCSS 225.7
2 APM ARENA 468.5125 AU CTCSS 225.7
3 APM PORT NET 456.5875 AU DCS 731
4 APM HAZMAT 1 457.7125 AU DCS 125
5 APM HAZMAT 2 456.2875 AU CTCSS 141.3
6 APM CHARLEY R 452.3875 AU DCS 624
7 APM SAFETY 456.8875 AU DCS 131
8 APM FACILITY R 452.7625 AU DCS 271
9 APM BLUE R 451.9625 AU DCS 664
10 APM POWER R 452.6625 AU DCS 516
11 APM RTGMECH R 464.9625 AU DCS 731
12 APM REEFER 457.6625 AU DCS 712
13 APM CHASSIS R 461.2125 AU DCS 503
14 APM YARD R 461.4625 AU DCS 365
15 APM RAIL R 462.0375 AU DCS 143
16 APM SECURTY R 461.7625 AU DCS 503
Old 02-02-2013, 10:03 PM
maalox's Avatar
thanks e911god.
Chauffeur6's Avatar
DB Admin
Yup, that matches up with what I submitted.
I have no idea why they were all entered with 00 as the Home LCN, and yet had the Home LCN noted in the description or subcategory notes. That makes absolutely no sense.
Old 02-02-2013, 10:05 PM
e911god's Avatar
Moderator
LCN 15 and 19 are correct in the DB (I should put my glasses on).
Old 02-02-2013, 10:09 PM
Chauffeur6's Avatar
DB Admin
I only submitted the changes to the TGID's, not the frequencies, so it should be good once the corrections are made.
It's nice that maalox decided to listen to the system, and pointed out it wasn't in the HP-1 database. Makes me wonder how many other systems are in the RRDB with obvious errors like that?
Old 02-03-2013, 5:06 AM
maalox's Avatar
i did program this system in the 996xt and did not hear anything i well try and see with the homepatrol
Old 02-03-2013, 10:39 AM
e911god's Avatar
Moderator
I think the license only lists it at 2 watts ERP ! I hear it good around the Port and over by EWR...I never really tried to listen from distances, but I'll see what kind of reception I get when I go back into work on Monday.
Old 02-04-2013, 9:46 AM
maalox's Avatar
im scanning port newark on my 996xt nothing e911god was right only 2 watts be great if some can put up a live audio for port newark .
Old 02-04-2013, 11:44 AM
RadioDitch's Avatar
They were on pretty busy last night while listening from my family's place in Galloping Hill/Elmora area.
73, W2MJR/EI7D
EMT/Railfan/Certified Nerd
Union County, NJ - Morgan County, WV - Baldoyle, IE
Confucius Say: "Communications techs do it on-air."
Old 02-04-2013, 12:39 PM
maalox's Avatar
i must be out of range i am using a roof antenna .
Old 02-04-2013, 5:45 PM
Chauffeur6's Avatar
DB Admin
The system is now available in the HP-1 database as of today's update.
Old 02-04-2013, 7:09 PM
maalox's Avatar
its in the essex or essex county. thanks
