Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum - Forum for discussing Radio Information in the State of New Jersey.
Old 05-13-2013, 10:03 PM
Default Jersey City Fire
Does anyone know what CH-2 is for JCFD. I know the 2 460MHz frequencies but apparently there is a channel 2. They have 472.175 licensed but I have yet to hear anything. JCFD refers to the 460MHz freq's. as CH-1 and CH-3.
Thanks,
Bob
Old 05-14-2013, 1:00 PM
jaymatt1978's Avatar
Usually when that happens channel 2 is the same as channel 1 in SIMPLEX. It's like that on MOST FD like Newark, among others. I know Paramus FD constantly refers to Channel 1 (453.1500) and Channel 3 (453.375))
Old 05-14-2013, 4:50 PM
Ch 2 AKA F/G 2 is 460-550
Ch 3 AKA F/G 3 is 460-600
Ch 4 is simplex for Ch 2
Ch 5 is simplex for Ch 3
That the only analog channels JCFD uses.
Old 05-14-2013, 5:04 PM
472.175 is licensed to JCFD and is listed with a DPL 023, so how does that fit into the scheme of things? If they only use the 460 frequencies, why is the 472 frequency listed?
Let's get the database corrected if it's wrong. These are the current listings:
460.550 (192.8 PL) - Channel 1 Command Staff
460.600 (192.8 PL) - Channel 2 Dispatch and F/G
472.175 (023 DPL) - Fire Simplex 9
Old 05-14-2013, 6:21 PM
It is licensed to them, and it is active (the license). If you remove it from the database and JCFD decides in the future to use it, then what? ULS License - Public Safety Pool, Conventional License - WPPC224 - JERSEY CITY, CITY OF
Old 05-14-2013, 6:51 PM
Calm down, I never said I was removing it.
I'm asking jcityfire what that frequency is used for, since he states that the only analog frequencies they use are the two 460's.
PS - Just because a frequency is licensed doesn't mean it's actually being used or should be listed in the database. There are a ton of frequencies that get licensed that never see the light of day. An active license means nothing when it comes to the RRDB. I'm not saying that's the case here, because obviously at some point someone heard JCFD on that frequency based on the report of a DPL being used, but it's something to keep in mind.
Old 05-14-2013, 7:53 PM
I am quite calm.
I'm very aware that just because a frequency is licensed doesn't mean it's being used. This isn't my first time on this website.
Old 05-14-2013, 7:55 PM
Yes, I'm well aware of your history of multiple accounts on this site.
Old 05-14-2013, 7:59 PM
What's that supposed to mean. Are you trying to be a WiseA**?
Old 05-14-2013, 8:13 PM
It means this is not your first account on this site..."ems540", "dubenezic", etc. Creating a new account doesn't mean your history on the site is forgotten about, including infractions and temporary bans you've received in the past. You've got enough of a history of being a wisea** on this site yourself, so don't be so quick to get hostile or offended by me calling you out. You've got this new account now, you should probably lost the attitude so you can keep it. That is all, now get back to the topic of your thread.
Old 05-14-2013, 8:17 PM
I was never ems540. Get your facts straight. You're calling me out? Let some of the air out of your head. It's inflated. When you stop i'll stop, not the other way around.
Old 05-14-2013, 8:36 PM
svfd17's Avatar
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.0.4; en-us; C5170 Build/IML77) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Wow.
Old 05-14-2013, 11:03 PM
I'd be curious to see the full conventional mode layout for the JCFD.
Old 05-16-2013, 2:38 PM
472.1750 isn’t in any JCFD radio and they have just been all reprogrammed. 472.1750 may have been a data channel that was used for the MDS that were in use for a short period. If for some reason it is programmed in to the radios, I will ask for it to be added to the database if it’s removed.
Old 05-16-2013, 2:53 PM
Thanks, I've updated the database.
Old 05-23-2013, 8:11 AM
Does that mean that they've changed their channel plan from what you have listed at the bottom of: Bergenscanner.com - Paramus Unit Numbers ?
Patrol Air Civil
Old 05-23-2013, 2:34 PM
No I confused Elmwood Park and Paramus the p[lan on Bergenscanner is correct! SORRY
Old 05-24-2013, 9:25 PM
Jersey City recently rebanded their radios. Channel 1 is now their digital trunk channel 1 (refer to FDJC digital trunk system.) Everything else has just been pushed back. Analog Dispatch is on Ch. 2 with units switching to ch. 3 on EMS runs.
Old 06-02-2013, 11:12 AM
Sounds like they are doing extensive testing of new system from a 40 story high rise operating on talk group 2008 which was referred to as fireground 7 if this helps
Old 06-02-2013, 8:04 PM
Word has it that JCFD may try to go online with the P-25 system stating Tuesday.
