Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum Forum for discussing Radio Information in the State of New Jersey.
Old 11-20-2013, 10:50 AM
W2SJW's Avatar
Senior Member
Default Somerset County 700 MHz P25
Guys,
Since I no longer live in the area, I need a favor from a fellow member - I need someone with Pro96com to run the 700 system for a day & confirm what TGID's are regularly being broadcast on that site (besides the 2 TDMA simulcasts).
If you could post, or PM me the log file, that would be greatly appreciated!
Sent from my Galaxy S4 via Tapatalk 4
Scott
NJ & PA Database Admin
My BCDx36 Files
Old 11-22-2013, 9:33 AM
mdragon's Avatar
Recording for an hour, here's the data so far.
Old 11-22-2013, 11:35 AM
mdragon's Avatar
from 9:30-12:30
Old 11-22-2013, 11:37 AM
I believe he was looking for logs on the 700 MHz site, not the UHF site.
Old 11-22-2013, 11:42 AM
mdragon's Avatar
Thanks I read right past that. 700 it is, recording now.
Old 11-22-2013, 12:36 PM
mdragon's Avatar
Take 3 this time on 700
Old 11-22-2013, 1:08 PM
W2SJW's Avatar
Senior Member
Thanks! This is exactly what I was looking for. The channel ID table also confirmed what I thought I saw in my own limited monitoring before I moved out of the area - that table ID #3 is not the standard 851.00625 that many P25 systems use, it's 851.0125.
I gotta go back now & look at my NJICS logs from the last few months...
Scott
My BCDx36 Files
Old 11-22-2013, 1:32 PM
mdragon's Avatar
One last dump of the 700, about another 45 minutes of data.
Old 11-22-2013, 1:34 PM
The standard bandplan for 700/800 TDMA systems is as follows:
00 - 851.00625 - 6.25 - 1 slot FDMA
01 - 762.00625 - 6.25 - 1 slot FDMA
02 - 851.01250 - 12.5 - 2 slot TDMA
03 - 762.00625 - 12.5 - 2 slot TDMA
There's nothing unusual about the Somerset 700 site, it's the same bandplan as the NJICS, Rockland's system, etc.
Old 11-22-2013, 1:38 PM
W2SJW's Avatar
Senior Member
Thanks Chris!
I did not know that...
Scott
My BCDx36 Files
Old 11-22-2013, 1:44 PM
No problem, Scott.
There are some exceptions to the rule. The Waterbury, CT system uses a base of 851.0625 for table 00 instead of 851.00625, for whatever reason.
Waterbury Trunking System, Waterbury, Connecticut
