Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum Forum for discussing Radio Information in the State of New Jersey.
Old 01-22-2014, 3:30 PM
dconti's Avatar
Default Where did the Pal Interstate Parkway PD Go?
Brought up their VHF freq as listed in the database for last night's storm, and crickets?
What gives? If they moved, is anyone going to update the database?
Old 01-22-2014, 4:04 PM
railtrailbiker's Avatar
They have been using the NJICS 700 MHz system for quite some time now.
Old 01-22-2014, 4:49 PM
trsundstrom's Avatar
Mentor
Wirelessly posted (Moto Droid Bionic: Mozilla/5.0 (Linux; U; Android 4.1.2; en-us; DROID BIONIC Build/9.8.2O-72_VZW-22) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Dconti, I believe the RR SOP is to retain entries so long as the FCC license is not expired or cancelled. HTH.
Tom - W2XQ - w2xq.com
Old 01-22-2014, 7:09 PM
dconti's Avatar
Are they operating under a specific agency or must one monitor the entire system for the PIP PD?
Old 01-22-2014, 7:33 PM
Mentor
You can limit the scan to the particular talk groups IDs the Pal police dept uses.
Old 01-22-2014, 7:46 PM
PJH's Avatar
PJH PJH is offline
Multistate DB Admin
Depending on the cut over, the freq may be listed as "depreciated" or outright deleted. In the handbook, the deprecated freq's should not remain in the database for a long period of time. The uniden software will see that tag and not scan a depreciated channel.
If you have received a PM from me about a submission, kindly reply within 5 days with requested information or your submission may be rejected. Thanks!
Old 01-22-2014, 7:48 PM
dconti's Avatar
"You can limit the scan to the particular talk groups IDs the Pal police dept uses."
OK, can anyone tell me the talk groups IDs?
Old 01-22-2014, 8:00 PM
New Jersey Interoperability Communications System (NJICS) Trunking System, Statewide, New Jersey - Scanner Frequencies
is the link to the NJICS. Scroll down until you see Palisades Interstate Parkway Talkgroups about halfway down the screen. The DB is showing that they are using P25 Phase II talkgroups which can only be monitored with a GRE PSR 800 or either one of the new Unidens that are expected out any day now. And it shows they are using encryption sometimes on these TGID.
David, KE4MCJ
PSR-800, PSR-500, PRO-197, PRO-106, PRO-163, ICOM IC-T81A, YAESU FT-8800R, etc.
Old 01-22-2014, 8:11 PM
btshep's Avatar
What kind of scanner are you running ? The PIP talk groups are Phase II which can only be monitored on the GRE PSR-800 or the new Uniden BCD-436HP & BCD-536HP scanners which just started shipping this week.
The info for the NJICS system can be found here: New Jersey Interoperability Communications System (NJICS) Trunking System, Statewide, New Jersey - Scanner Frequencies
Note: Encryption sometimes heard on these talkgroups
DEC HEX Mode Alpha Tag Description Tag
4201 1069 T PIP PD P-1 Palisades Interstate Parkway Police (Patrol 1) Law Dispatch
4203 106b T PIP PD P-2 Palisades Interstate Parkway Police (Patrol 2) Law Talk
Old 01-22-2014, 10:33 PM
dconti's Avatar
Thanks for the information. Currently running HP1 scanners in the base and mobile.
Not quite ready to drop another 5 or 6 hundred bucks on another scanner to listen to the PIP PD, and certainly not until user reviews are forthcoming and the prices drop, which they will.
Thanks again.
Old 01-23-2014, 6:12 AM
IF it matters the VHF freq is still used to communicate with local EMS/Parmedics when responding to incidents in the park
Old 01-23-2014, 8:51 PM
RadioDitch's Avatar
FWIW. As crazy as it sounds, the use of encryption isn't a matter of policy but rather is arbitrary depending on who's dispatching. Most enable the encryption, others are fellow radio geeks and turn it off at the dispatch console (and they can on their setup).
So it's a matter of listening on the right night.
73, W2MJR/EI7D
EMT/Railfan/Certified Nerd
Anywhere from Crawford, NE to Preghane, Ireland
Be a man. Drill it! Support Hams Against Magnetic Mounts.
