Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum - Forum for discussing Radio Information in the State of New Jersey.
Old 04-15-2014, 10:09 PM
elias1988's Avatar
Default Jackson Township Fire
All fire departments are now utilizing Fire Operations 1 TG on the Jackson TRS with communications still with Ocean County.
BCD436HP|BCD536HP|Pro-106|XTS2500UHF|BaoFeng UV-82C|Minitor V|Unication G5 UHF
NJ-443-Breaking News Network-Ocean County,NJ
Seaside Heights Current Weather Conditions
Old 04-19-2014, 2:40 PM
elias1988's Avatar
Communications have now switched back to OCPS 6.
Old 04-23-2014, 3:32 PM
elias1988's Avatar
Seems like FD has switched back to the township TRS,I'm currently hearing station 54 units on Fire Operations 1.
Old 05-22-2014, 8:53 AM
DJ88's Avatar
Anyone know what they're using for response/fireground now? All four companies were dispatched this morning for brush trucks mutual aid to Freehold for a structure fire and not a peep on OCPS6, the TRS, or either of their Tac channels.
My Toys:
Uniden BCT15X | Uniden BCD996T | Uniden BCD396T
Uniden BC785D | Bearcat 210XLT
Old 05-22-2014, 9:47 AM
elias1988's Avatar
I'm not sure if this has something to do with it:
ULS Application - Public Safety Pool, Trunked - 0006292502 - JACKSON, TOWNSHIP OF
Edit:I'm currently hearing 5621 and 5610 communicating on Fire Operations 1.
Old 01-18-2015, 10:09 AM
ErikAtTheW's Avatar
Default Jackson Ops
Any update on this?
I'm still trying to figure out what system Jackson is operating on.
I have the Jackson trunk system as well as the Ocean County system programmed (hopefully correctly) but I am not hearing any apparatus after dispatch.
Can anyone help?
Thanks,
Erik
Erik
Old 01-18-2015, 11:26 AM
elias1988's Avatar
They operate on the Jackson Township trunked system and are digital,if I remember correctly didn't you message me on Facebook about this? You gave me the scanner model you're using as BC 780xlt which doesn't do digital so that's why you're not picking up fire operations after dispatch.
Old 01-18-2015, 11:31 AM
ErikAtTheW's Avatar
Yes, that was me.
I replaced the 780xlt with a BCD996XT.
Erik
Old 01-18-2015, 11:43 AM
ErikAtTheW's Avatar
I'm hearing Ocean County on 508.1875 which is in the RR Database as OC Fire/EMS Dispatch, but I hear nothing on the Trunk system for Jackson.
I have it programmed as a P25 Standard (Digital XT) Site Type, I have the 6 Trunk Frequencies in, I have all of the Fire Ops TGIDs programmed and I'm using Free Scan to program it.
I can pick up the Ocean County Trunk system, the Joint Base system, the new Mercer Trunk system, NJSP no problem, just no Jackson.
Erik
Old 01-18-2015, 11:55 AM
Highpockets's Avatar
Try setting it up as a Mot Type II/P25 and use the band plan that is in the database.
Old 01-18-2015, 11:58 AM
ErikAtTheW's Avatar
I have no data in the APCO Band Plan table, is this correct? Or is this what you are suggesting I enter? Just trying to be clear.
The software will not let me enter APCO Band Plan Data if I set it to Mot TypeII/P25
Erik
Old 01-18-2015, 12:03 PM
Mine is set up as a Mot Type II/ P25 system and use the band plan that is listed in the database and it works.
Old 01-18-2015, 12:06 PM
ErikAtTheW's Avatar
What software are you using?
Erik
Old 01-18-2015, 12:14 PM
FreeScan, here is a copy of my file. You'll have to unzip it to get the .996 file.
Old 01-18-2015, 12:36 PM
ErikAtTheW's Avatar
Ok, Trying this. Thank you!
Erik
Old 01-18-2015, 12:44 PM
Unzip the example file into your freescan directory, open it with freescan and you'll be able to check it out. Hope it helps, let me know.
Old 01-18-2015, 12:54 PM
ErikAtTheW's Avatar
I just programmed it as yours is set up. Waiting to see what happens!
Thank you
Erik
Old 01-18-2015, 1:03 PM
Thank you
I haven't used my 996 for a long time, it might not work, I just looked at that file and it looks like I have the audio set to analog and it should be digital, let me fool with it and see if I can hear Jackson today.
Sorry, I should have checked out that file first. I use my GRE600 most of the time.
Old 01-18-2015, 1:40 PM
Thank you
Strange, I can't get Jackson now either, I'll have to fool with it.
Old 01-18-2015, 2:36 PM
ErikAtTheW's Avatar
Well it looks like I have it working now. Your System Band Plan had 507.000 as the second Lower Freq number, it should have been 507.400.
Erik
