Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > New Jersey Radio Discussion Forum
New Jersey Radio Discussion Forum - Forum for discussing Radio Information in the State of New Jersey.
Old 05-24-2014, 9:05 AM
K2YYN's Avatar
NJ Data Base Admin
Exclamation NJ SPEN 1 154.680 PL131.8 Jammed?
Since this Friday evening 5-23-14 22:00 there has been and continues to be a very strong carrier on this frequency with PL. Strongest signal is in North East New Jersey (South Bergen, Essex, Hudson and South East Passaic County).
The SPEN frequency is unusable in these areas and is practically is jammed at this point.
Perhaps during last night's T-Storms a lightning strike or power surge tripped a transmitter or relay point in some state, county or municipal agency unawares.
Not far from reality it also can be someone purposely jamming the frequency?
Max
Old 05-24-2014, 11:32 AM
scannermanner1's Avatar
Could be a repeater problem!
Old 05-24-2014, 12:05 PM
Skypilot007's Avatar
It's a simplex channel with occasional patches.
This channel used to get quite entertaining with different law enforcement agencies and others playing games on there.
Old 05-24-2014, 12:15 PM
Not hearing the carrier here in the south part of the state.
Old 05-24-2014, 1:11 PM
Not heard in morris county, is it still active. last time this happened it was Fairview in Bergen County, I wonder if they plugged in that equipment again.
Old 05-24-2014, 1:19 PM
JMR3865's Avatar
Have it here in Monmouth County. Seems as if it started around 21:49. No mdc id's until 0657 of id 0352.
JMR
Old 05-24-2014, 1:22 PM
I heard it the pas couple days and even this afternoon for a few mins. I did hear some repair guys on this morning but could not make out where from they were very garbled.
SPEN-4 is active now with some kind of activity (rare, as SPEN -4 is usually quiet) and just now I'm getting the open carrier again on SPEN-1
best guess is its SW of Nutley from a little direction finding
Old 05-24-2014, 1:36 PM
"Entertaining" is a poor choice of words, but I get your drift.
Yes, SPEN-1 is abused, perhaps by otherwise bored dispatchers. I'm surprised that the NJSP hasn't done some type of investigation of it to see if they can pinpoint the chronic abusers. And, if found, give them their due process.....then FIRED. Police CHIEFS should also be cited for "failure to supervise" their dispatchers.
As we all know, someday someone will want to break their boredom with immature and inane radio transmissions on SPEN-1 just as a chase or some type of 'shots fired' run is being transmitted, and no one will hear it. And we can all realize the danger in that, I'm sure. And a scenario like that would fall under the legal definition of "Gross Negligence," which would make the department involved, as well as the dispatcher, civilly...if not criminally....liable for any failure on their department or another department to take necessary police action. And if you're a dispatcher, forget about being indemnified. You will be personally indebted for a LONG time if you are found to have willfully committed the Gross Negligence.
Old 05-24-2014, 4:35 PM
[QUOTE=ten13;2192726]"Entertaining" is a poor choice of words, but I get your drift.
As we all know, someday someone will want to break their boredom with immature and inane radio transmissions on SPEN-1 just as a chase or some type of 'shots fired' run is being transmitted, and no one will hear it. And we can all realize the danger in that, I'm sure. And a scenario like that would fall under the legal definition of "Gross Negligence," which would make the department involved, as well as the dispatcher, civilly...if not criminally....liable for any failure on their department or another department to take necessary police action. And if you're a dispatcher, forget about being indemnified. You will be personally indebted for a LONG time if you are found to have willfully committed the Gross Negligence.[/QUOTE
POLICE CHIEFS do not own the dispatch center(s) or the dispatchers
Old 05-24-2014, 5:41 PM
K2YYN's Avatar
NJ Data Base Admin
Thumbs down Still There
Unfortunately the carrier is still there and quite strong from my location here in NE NJ .
Perhaps with the Momerial Day Holiday weekend in full swing the proper personnel who would be around to check and correct this problem are far far away with their families on vacation.
I figured the final amps would have blown, heated up or burned out by now. Heavy duty cycling and great heat sinks!
Politics be dammed! Perhaps no one gives a #*+^!
The shame of it a public safety person may get hurt or worse just because this frequency has been made useless due to technical or human failure or just for a plain lack of interest or concern. I sincerely hope not...)
Max. Trying to be about this.
Old 05-24-2014, 9:33 PM
railtrailbiker's Avatar
The FCC has equipment on line that is capable of pinpointing the carrier's source within minutes of notification to their 24/7 operations center.
I'm curious to know why someone at NJSP hasn't called them about the problem.
Here's the contact information:
Emergency Contacts for the Public Safety & Homeland Security Bureau | FCC.gov
Old 05-25-2014, 12:18 AM
AC2OY's Avatar
I had to hit avoid last night several times all I got was a loud buzzing.
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Uniden 536 HP Kenwood TS-2000 Comet 250-B Diamond D3000N
Old 05-25-2014, 12:36 AM
Has anyone tried RDFing, On the open carrier?
Old 05-25-2014, 9:18 AM
"POLICE CHIEFS do not own the dispatch center(s) or the dispatchers"
Maybe in your isolated world, but there are STILL some small-town PDs whose dispatchers sit two or three doors away from where the chief holds court everyday, worrying more about his appearance at the local Elks Club and balancing his personal check book than the operation of his police department. And, as far as the supervision of the SPEN operation (or, apparently, the LACK of supervision), those chiefs are just as responsible, if not more so, for the dangerous operation of the radio.
Old 05-26-2014, 6:55 PM
AC2OY's Avatar
Ok so it's still out? Newark NJ has about one shooting a minute and stolen car chases. What happens when they key up and say "Newark PD to surrounding towns"? I can't believe this hasn't been resolved as of yet?!
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Old 05-26-2014, 7:17 PM
So what difference does it make if PD and Dispatch are in the same building ???? Dispatch is dispatch , they have there own supervisors/managers!
Old 05-26-2014, 11:59 PM
Huh? Newark only bothers to turn up the volume on SPEN-1 if THEY have initiated the broadcast. For as long as I can remember, the two most common phrases transmitted on SPEN:
- "Knock it off, North Bergen"
- XXXXXX to Newark on SPEN, - SILENCE - SILENCE -- XXXXXXX to Newark on SPEN, we have a chase in progress on 280e just about to enter your town. - SILENCE.
Last time this happened, "Goosetown" communications out of NY had a mobile vehicle out on the road that pinpointed it to mobile radio with a bad mic or some similar problem as FCC Enforcement was busy with Superbowl ops.
SPEN was about the only thing NJ did right in terms of communications over the years, but they failed miserably when they went with the ge & midland junk. Simplex VHF is a great b/u for true interoperability, but they should simply mandate ANI (won't stop idiots with baofunk junk, but would be good at identifying equipment problems)
It's all ok though. Everything will be just dandy when T-Band is auctioned off to one of O'Bummer's buddies and 700 D block is the spectrum of the land. It works everywhere, anywhere and will never, ever fail.
It will suit the needs of every agency, big & small and should propagate well in all terrain. Just like government healthcare
Old 05-27-2014, 10:56 AM
AC2OY's Avatar
WOW I kinda agree with you SPEN did work well.
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Old 05-30-2014, 11:25 PM
AC2OY's Avatar
SPEN is working well again I guess they fixed it!
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Old 06-06-2014, 8:51 AM
902's Avatar
902 902 is offline
I jumped in a little late, but I had a similar situation on a fire mutual aid channel in another region. Intermittent carrier. It's up, it's down, etc. This might help isolate a problem next time:
Listen carefully not to the content of the transmission, but the keyup. Do you hear a very short, high pitched beep? It could be the trailing end of the 1950 Hz tone remote keying sequence. If you heard the signal full quieting, and you turned up the volume, do you hear a high pitched (2175 Hz) tone hanging down in the background? If so, there is a high probability that it is a base station that's tied to a tone remote.
Take a mobile radio, a portable, and a hand-held scanner with the antenna off. Drive down the Interstate or a main road. If you hear the interference on the mobile radio and not the portable, you're not close to it. If you hear the interference on the mobile and the portable, cruise past known locations where there are transmitters licensed. The scanner with no antenna on it should start hearing the transmission about a block away.
It's a little more difficult tracking malicious interference, but it's not impossible (it's pretty easy, actually).
Or, you could have a group of people with Doppler direction finders or Yagis deployed working with each other (or plotting vectors to triangulate). Even one person can do that pretty easily, but it takes more time.
Here's the best part: in my situation, when I found the base station, the problem was not at that site. It was at a firehouse about a mile or two away. They had a desktop tone remote control unit that someone spilled coffee into. The coffee gummed up inside the remote and was intermittently shorting the PTT button into transmit. It was taken apart, scrubbed clean with a toothbrush and rubbing alcohol, and left to air dry. Worked just as good as new after that.
Moral of the story: equipment failure is more prevalent than malicious interference. The same tactics are used to find it.
