Analogrules
- Joined
- Jan 15, 2007
- Messages
- 1,948
Is it legal for contractors/businesses to use Family Radio Service frequencies?
Wow, very interesting. I am surprised more businesses/stores don't use them in that case.
However, even though it's technically not legal to transmit on FRS using a Baofeng, I would not be surprised if many businesses are buying those radios now to communicate and set them to an illegal 4 Watts, high power. As long as they aren't interfering with public safety, no one may even notice.
the primary reason of using 67.0 is because it's the lowest ctcss tone. i had also heard that supposedly the lower you went in ctcss, the more stable the tone was ?. i wonder how many get setup in csq.
It has more to do with it being the "default" tone on many consumer radios. In other words, when they take them out of the box, they already have it activated on the channel. If they don't know what it is, they usually don't mess with it.
Some Radio Shack GMRS radios came with the 100Hz tone as default many years ago. I used to use 462.550 with a 100Hz pl tone as my "family" channel. Every year the county fair would be in town and I'd have to listen to them since it was the default channel/tone on their radios.
I've heard, over the years, that higher CTCSS tone frequencies can decode faster, but in reality we are talking about a few milliseconds. Not that anyone could really "hear" the difference.
One issue with the higher frequencies is that they can end up in the audio stream if the radio doesn't have a low cut filter. Some higher CTCSS tones, like 254.1hZ will come across in the speaker as a low rumble in the background. Most commercial radios have a low cut circuit in them that will prevent this from happening, but some radios don't.
With modern radios.. At least to my knowledge I've never experienced any " humming noise" from using higher tone codes or even DPL inverted tone codes. That seems to me at least a problem from the past with older radios and/or lower end repeaters where having higher PL and DPL tone codes created a problem on either the input or output end for radio transmissions.
I've seen allot of paving companies such as cutler using frs, murs to own licensed intinerant frequencies. I noticed this with other companies and flag men to small site construction projects. Most aren't a bother. Sometimes interesting actually. I recall once a paving company working on interstate 10 late using murs near a wal mart. Wal mart went and told them over the radio to get off their frequencies now or they'll report it to fcc lol. They were using csq and the construction a pl. Next day the company was using frs and continued to during the work.
