Hi DJ88 and all,
"The frequency is actually 453.5375. The last number doesn't register on the older scanners, but you still receive it."
Yes and no, let me explain for the benefit of the newbies. The frequency is the closest the PLL can manage but in any case the last digit would be 5 except for the display error. 5kHz increments is the best the PLL can divide the frequency of the master injection oscillator. In this case "center frequency" would be .535 but for the IF offset. Confusing? Not really, since the IF won't track between VHF and UHF if the signal were centered it's offset a bit and the passband is wide enough to accept it. The IF signal is shifted in the passband one way for VHF Lo and Hi, then shifted the opposite way for UHF because the on air frequencies are allocated likewise.
For what it's worth most passbands are 14kHz wide which doesn't afford very good adjacent channel rejection so if bleed over is a problem just program 5kHz up or down to get away from the other signal.
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
