Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > New Mexico Radio Discussion Forum
New Mexico Radio Discussion Forum Forum for discussing Radio Information in the State of New Mexico
Old 06-05-2009, 06:52 PM
drgensel's Avatar
Send a message via AIM to drgensel
Default Live broadcast
I have my live broadcast back up and running. It should be up the majority of the time, however for the next few days I will be working out some kinks so it could be up and down. For one, When the radio is charging, there is a hum after every transmission....I have no idea why, never noticed that before.
Anyway, just wanted to let everyone know its back up and should stay that way!
Kevin
http://apdpatches.netfirms.com/rrdps.html
Old 06-05-2009, 07:14 PM
brandon's Avatar
Nice feed. It's not very often you get to monitor a ProVoice system via the web
Old 06-09-2009, 06:25 AM
drgensel's Avatar
For now, the feed will be down again. I need to find the source of the background noise before I let the feed run continuously. I think the answer lies in the sound card...same issue I had with my last setup. Thanks for being so patient.
Kevin
PS -- If anyone has any other ideas, let me know...the sound through the "line in" is terrible, there is background noise after every transmission. Though the microphone jack is better, it "crackles" from time to time and I am going to need to use the mic for other things as well. I did try two different cables, same issue with both.
Old 06-09-2009, 08:31 PM
abqscan's Avatar
DataBase Administrator
Send a message via AIM to abqscan Send a message via Yahoo to abqscan
Have you tried a attenuation cable? I know the audio signal that comes out of my EDACS radio is pretty hot!
Old 06-21-2009, 08:37 PM
drgensel's Avatar
Until I come across an attenuation cable, I have made some modifications to my setup and it sounds pretty good so far. Can someone listen in and let me know how it sounds?
Thanks,
Kevin
Old 06-21-2009, 10:16 PM
abqscan's Avatar
The audio still sounds a little hot, just a little. I get a 60 cycle hum every once and a while as well.
Old 06-21-2009, 10:20 PM
drgensel's Avatar
Yea, it still hums, but its definitely better than it was. Any idea where I can get a cheap attenuation cable? I think its just the sound card, but if the cable helps its probably cheaper than buying another card.
Old 06-21-2009, 10:22 PM
abqscan's Avatar
give this a try:
6.5-Ft. Attenuating Dubbing Cord with 1/8" Phone Plugs - RadioShack.com
Old 06-23-2009, 10:28 AM
I've listened to this feed for a few days and did not pick up a hum or any other problems on it.
How did you manage to track a Pro-Voice system?
A suggestion, why don't you put this feed on Scan America, which RR now owns and is very convenient to use. The way RR has it set up it is quite easy and simple to locate feeds.
Old 06-24-2009, 08:52 PM
drgensel's Avatar
OK, thanks for the help so far. I have started using the attenuating cable...sounds good to me. Let me know what you think.
Thanks again,
Kevin
Old 06-29-2009, 12:30 AM
drgensel's Avatar
Consider it done...should be live as we speak.
Old 06-30-2009, 11:00 AM
You are awesome!
Old 07-03-2009, 09:09 AM
Moto_Jedi's Avatar
I'd just like to thank you for your effort in making the ABQ feed available. I've had it bookmarked for over a year and I've enjoyed it numerous times, when I've been in the mood for it.
Regards,
Terry
Old 07-24-2009, 08:35 AM
drgensel's Avatar
The low audio issue with the feed should be resolved this weekend. The problem appears to be with the patch cable. Once unplugged and allowed to cool down, it works fine for a day or two. I will replace it and that should resolve the issue once and for all.
Old 09-17-2009, 06:52 PM
Thank you for the broadcast and info. I moved here from Colorado and I started listening about a month ago. I have a Uniden BCT8 and I can only listen to dispatch. What kind of radio are you using if you don't mind me asking?
Thanks once again.
Chris
Old 09-18-2009, 07:55 AM
drgensel's Avatar
Thanks once again.
Chris
It's a LPE-200 Scan Model. I purchased it on Ebay five or so years ago.
Old 09-18-2009, 06:09 PM
Is it easy to program?
Old 10-18-2009, 07:30 AM
drgensel's Avatar
The feed will be down until further notice. I believe the recent low audio issues were ultimately followed by the speaker mic completely dying last night. Until I can replace the speaker mic, I may stream the audio from the analog dispatch frequencies....
Old 10-28-2009, 11:03 PM
I hope the Albuquerque feed will return soon, it is of great interest to me being that it is the only
way to hear APD, so nice to know what is going on around you when you work a security post, and I know about four others that enjoy it also, please let us know how things are going and
thank you for your trouble.
Old 10-29-2009, 09:55 AM
drgensel's Avatar
Issue resolved, feed is back online and sounds fine.
Similar Threads
81 new feed links added to my site and other updates jasonpeoria911 Streaming / Broadcasting / Audio Recording 16 04-18-2008 06:42 PM
live tv news cameras eclipsecivic2002 Washington Radio Discussion Forum 2 02-14-2008 09:51 PM
LVMPD Feed Live 24/7 VEGASBUFF Streaming / Broadcasting / Audio Recording 0 08-10-2007 10:09 PM
Live Feed - Youngstown,Ohio digitalanalog Streaming / Broadcasting / Audio Recording 0 05-19-2007 02:05 PM
Incident News Broadcast provides live real time feeds from various saveourtrainsmichigan Streaming / Broadcasting / Audio Recording 0 03-07-2007 02:24 PM
