Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > New User / Getting Started Forum
New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community.
Old 03-09-2009, 08:33 PM
chris24go's Avatar
Send a message via Yahoo to chris24go
Default I just got a replacement 996T Scanner
I live in Spotsylvania, VA DC/METRO area. My first scanner was preprogramed for me with PUBLIC SAFETY and DOT/GOVT/FREQ. I am not a techie. And the 996T preprograms are picking up nothing, I also can't hook op to computer with cable supplied I only have a 15 pin and onw supplied is a 10 PIN appreciate any help I can be IM'ED on Yahoo @ chrissefchick
Old 03-09-2009, 09:12 PM
The cable supplied is probably a 9 pin serial cable. The 15 pin connector on the computer is probably for a video monitor. They are not going to talk to each other. If your computer has no 9 pin serial connector as is fairly common for newer computers, you then, no doubt, have USB ports on the computer. You will need to either get a USB cable for your scanner or an adapter that converts one of your USB ports to a 9 pin serial port. That will allow you to connect the scanner to the computer.
You will then, of course, need appropriate software to enable you to use the computer to program the scanner. If you don't already have that software, let us know and we can point you to some of the programs that will do the job.
Dick
Old 03-09-2009, 09:30 PM
chris24go's Avatar
When I go to store should I be asking for a usb for the 9 pin or usb to 9 pin adapter? Then is there any free software out that I can use to program? Appereciate your quick reply.
Old 03-09-2009, 11:00 PM
What I did was buy the Uniden USB cable for my scanner. That way you know it will work.
You can otherwise ask for a USB to serial converter, but it will usually cost nearly as much and you will have to make sure that it will work for you.
The free programs that I'm aware of that will work with the 996 are Freescan and BCTool. Of course, there may be others that I'm not familiar with.
Dick
Old 03-10-2009, 06:55 AM
loumaag's Avatar
Moderator
Add the Uniden UASD software, free to 996T owners.
Old 03-10-2009, 09:40 AM
MFD4305's Avatar
Question Just a Thought
All 996Ts come with LOTs of pre-programmed systems. I believe they have never been changed/updated since the model was introduced. If your original 996T received some traffic, maybe you just need to assure that the appropriate System Quick Keys are activated?
Remember: no matter where you go - there you are!
[Buckaroo Bonzai]
Old 03-10-2009, 08:00 PM
chris24go's Avatar
Dick
When I went to Radio Shack they were not aware of such of an adapter. but said if I come back tommorow they would be happy to clone there store model to my scanner. What do i need?
Old 03-10-2009, 08:03 PM
chris24go's Avatar
VA is programmed as well nationwide. I had my orginal one programmed before delived for the state and D.C..
I got the usb and the freeware from uniden com is know not reading my scanner. Any assistance would be appreciated. i don't mind if someone can go remote to check this our just let me know when to be on-line. I am also on yahoo IM at chrissefchick
Old 03-10-2009, 11:46 PM
loumaag's Avatar
Moderator
I would suggest that you avoid RS. They do have the USB to Serial adapter, but if they don't know it, it probably isn't the place to buy it. They will want too much for it anyway. Try almost any other retailer that sells electronics, even WalMart has one for less than $20.
Old 03-11-2009, 01:49 AM
I would hope that if they are going to do the cloning, they have what's needed to do it. Basically it's the cable, a null modem adapter and a gender changer according to the manual.
Dick
Old 03-11-2009, 09:34 AM
chris24go's Avatar
Can you possibly point me to a website. Appreciate your help.
Old 03-11-2009, 09:42 AM
n6tgk's Avatar
Send a message via MSN to n6tgk
That's Radio Shack for ya'. "You've got questions...we've got dazed and confused looks." As mentioned, go somewhere else. Radio Shack, for the most part, has been reduced to nothing more than a place to get cell phones, plans and accessories.
Stephen Mitchell, K7CB
Colorado Springs
Old 03-11-2009, 09:43 AM
n6tgk's Avatar
What kind of web-site?
Colorado Springs
Old 03-11-2009, 02:42 PM
chris24go's Avatar
I did and I got the software computer is know not recognizing the scanner
Old 03-11-2009, 02:46 PM
chris24go's Avatar
Old 03-11-2009, 09:17 PM
chris24go's Avatar
They were unable to clone to my Uniden from Radio shack but I got the USB and free software from uniden. Know my computer will not recognize the scanner. Any ideas. The BAUD rate for fron port is set at the highest (recomended by owners manual.
Old 03-12-2009, 01:02 PM
loumaag's Avatar
Moderator
I don't own a 996T but I do know that it depends on which port you are using on the radio to connect to. The front one is used for one thing the back one is used for something else. We need a 996T experienced user to talk you through which one is for connecting a PC to the scanner.
Old 03-12-2009, 01:38 PM
You should be able to use either port to connect to your computer. I use the front one. Anyway if you have a newer computer I'm sure you have multiple com ports. Your best bet is to go to settings, select com port 1 and a middle baud rate, and then hit OK. From there, select ONLINE CONTROL and it will attempt to read your scanner and display what your scanner is displaying. If it says ERROR or something, go back into settings and choose the next com port while leaving the baud rate the same. Try online control again. If you still have no luck, go through the all the com ports until one works. If none of them work, start playing with the baud rates. Try going lower before going higher.
If none of that works one potential issue might be that you have some sort of software that is monopolizing your com ports. Look into software you have on your computer that might be using them.
Old 03-12-2009, 02:13 PM
chris24go's Avatar
Owner's manuel says use from jack om scanner and use the high BAUD rating. IHow should I go about getting an experienced 996T programmer?
Old 03-12-2009, 02:32 PM
loumaag's Avatar
Moderator
Hi Chris,
I suggest that you concentrate your attention on the other thread you started in the Uniden Forum. I feel you will probably get faster and more on point help there, especially since you have already got the Uniden rep answering you there. Just remember to try and be as detailed as you can when stating your difficulty.
