There are a few do's and don'ts of on glass antennas.
1. They don't work on glass that has metal tint built into it. Some of the auto glass actually
uses metalic particles to cause the tinting. On this type of glass, no on glass antenna will work
at any frequency band. It acts as an RF shield also.
2. Do not mount any part of the antenna on or over the heater wires on or in the glass. These
metal strips will cause a problem with the coupling of the on glass antenna components. There
are small coils inside each of the two parts of the on glass antenna. These coils are what
does the transfer or coupling through the glass. The spacing between the two parts is
critical. If one of the pieces falls off, you just can't go to the local hardware store and get
some 2 sided sticky tape to put it back on with. Most of what you will find is too thick and
will effect the coupling through the glass.
3. VHF frequencies are hard to couple through the glass. The coils inside the 2 sections of the
antenna can not be made large enough to work properly. At UHF and 800 MHz, these type of
antennas work well. I have compared the glass mount to other antennas mounted through
the roof. If you use the same gain antennas, it is hard to see the difference.
4. The higher frequencies, like the 800 band should use the lower loss coax cable. So
if your going to use one of these, it pays to go after the better coax cable.
5. Don't plan on running any high power through the glass mount antennas. Your top
power point is about 50 watts. Above that you get into trouble with burning holes in
in the coax cable, issues at the through glass point and poor reliability in the
coupling coils. They just can't take the high power.
DO NOT UNDER ANY REASON WHAT EVER TURN DOWN A 100 WATT RADIO TO
50 WATTS OR LESS. The solid state PA's in radios today become very unstable at the
lower power levels. They tend to generate a bunch of noise, spurs and birdies. In general,
they don't make for good radio neighbors. You also stand the chance of letting the smoke
out of the PA stage of the radio.
Hope this gives you a little thought. One other comment, at least one on glass company
makes a VHF model. The down side to it is that the whip used is 36 inches long. Not
something what I would consider putting on my windows. When I talked with the engineer
that designed the antenna, I asked him why he couldn't use a 1/4 wave whip. His comment
went back to the coupling problem through the glass and the current points along the
coax cable.
Jim
Has anyone got a lot of experience with these?
Does window heater and factory tinting hinder the quality of reception?
