Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > New User / Getting Started Forum
New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community.
Old 05-28-2009, 12:28 PM
Default N00b question re bct15 programming
Ok, I've loaded my set of local frequencies, and pretty happy with the current programming.
When scanning, it appears that sometimes the scanner will land on a frequency that is programmed and will identify it according to the program, for example, it will display 155.XXXX - Tucson Police Department Sector XXX. Other times, it will land on this same frequency, and display some sort of generic identifier like Arizona - Public Safety. I assume that this is because the same frequency is found in both my custom programming, and in Uniden's Bear Tracker list, which is preloaded.
What I want is to force the scanner to display the correct ID data if it lands on a frequency that I've identified, and to display this sort of generic data only if I haven't programmed that frequency yet. How do I accomplish this?
Old 05-28-2009, 01:08 PM
RolnCode3's Avatar
Send a message via MSN to RolnCode3
Wirelessly posted (Tilt: 8900b/MR2 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.11) UP.Link/6.3.1.20.06.3.1.20.06.3.1.20.0)
Since it sounds like you want to also scan the preloaded stuff, your best bet is to lockout the individual frequencies (in the preloaded Uniden system) that correspond to the frequencies you have loaded yourself and tagged how you want them to display.
This is instead of turning off the Uniden preprogrammed systems.
It's a little early for me, so if this doesn't make sense, I'll try to clarify.
This is just what I would do. There might be other ways of getting the same result that I'm not thinking of.
Visit my Sac Area LE and Sheriff/PD feeds in the RR.com live audio area.
Similar Threads
General Programming Question firetaz834 Motorola Forum 4 07-03-2008 11:11 AM
Racom/Polk Co EDACS programming question butticeWB Iowa Radio Discussion Forum 4 06-09-2008 11:12 PM
PSR-500 programming question: Motorola Type II smokeyjones666 GRE Scanners 5 06-03-2008 02:22 PM
BCT15 Programming - DCFD ipweston Washington DC Radio Discussion Forum 3 04-03-2008 02:35 PM
Programming 785d Question jwile20vt Uniden Scanners 3 11-13-2007 11:08 PM
