| New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. |
07-09-2009, 08:13 PM
Radio Shack Pro-2096 Programming
Have the above mention radio. Trying to get reception on a local trunked system. All the freq's are programmed in. When the scanner stops at a frequency the voice is muffled and a DG appears in the upper right corner of the screen. Is there any other things I need to set to get it working?
07-09-2009, 08:23 PM
DG means digital and thati s normal.. what system are you listening to? & what antenna are you using?.. may be too far from the tower, in that case may need an outside antenna
07-09-2009, 08:27 PM
Listening to Sherburne County MN. I'm using an mobile antenna inside the house sitting in a window. Does the muffled voices indicate an antenna issue or something I need to prog differently. It is project 25 type system.
07-09-2009, 08:29 PM
Can you post your file.
07-09-2009, 08:31 PM
Not sure what you mean by post a file?
07-09-2009, 08:44 PM
On the reply to thread page you can attach the program file to your thread so others can move it to a program used to read it. I use Win96 if you don't program your scanner I may not be able to open your file, but I will look at the area you are trying to program in just a minute.
07-09-2009, 08:49 PM
I have win 96 also. I can load that file. I'm most interested in bank 0. I had no problem with reception using the mobile antenna I have been using. Give me a moment to figure out how attach the file
07-09-2009, 08:59 PM
the .p96 file does not upload it says it it an invalid type. Do you know how I can do it so you can view it? What file are you looking for from win96
07-09-2009, 09:08 PM
rename file to .TXT
07-09-2009, 09:11 PM
Also am here now & will look asap
Paul
07-09-2009, 09:25 PM
yes that is it
are you able to see the attachment?
07-09-2009, 09:28 PM
no sorry, try it agin or read your PM wil give u My email to send it to
07-09-2009, 09:31 PM
here is my email jimb@izoom.net Send me an email and I will attach it to the email
07-09-2009, 09:33 PM
sent
07-09-2009, 09:39 PM
sent the email with a zip file attachment
07-09-2009, 11:07 PM
Have you put in the tower site nearest you? All the red and blue CC's? It seems that you only have 4 or 5 TGID's for your county. You should be able to hear what ever else you program in for TG's.
Larry
Pro-106, Pro-163, Pro-99, Lafayette 200A, ScanFare VHF 4Ch Xtal, FT-60R
07-10-2009, 06:59 AM
It is also possible that that frequency he has in is encrypted also,he will hear gibberish.
Pro 2040 Scanner
Pro 83
Pro 2096
My Sweet Pro 106
Ronnie James Dio rules.....
