Originally Posted by KF5ALO
I keep seeing this stuff about rebanding supported Yes/No. Is this really a big deal if its not supported on a trunking scanner?
If you want a scanner, able to follow any/all Motorola Type I or Type II trunked radio systems, regardless of location, yes, you want a scanner that is supported for rebanding. Otherwise, you will lose the ability to trunk-track certain systems, as they move through the rebanding process & start using the updated frequencies.
See the rebanding
article in the Wiki for a more complete discussion.
Of course, for certain systems, which are not moving their frequencies, it's not going to matter at all. For others, that did reband, but moved to a set of frequencies the older scanners could still follow, it did not make the older scanners obsolete either. One example is the
Dallas City Local Govt. system. See this
thread for a brief discussion of why the older scanners still work. (There are others; I knew where to find this one quickly.)
For those systems which have not yet rebanded, but will, and will also be moving their frequencies to those an older scanner (say a Uniden BC780XLT, or Pro-97 for examples) cannot follow, you will lose the ability to follow them on the scanner in trunking mode. At that point, your options would be to either: upgrade to a rebanding supported scanner; enter the frequencies and follow what you could by listening to the system as conventional frequencies (meaning you'd hear everything on the system, not just the talk groups you wanted, trash trucks, sewer repair crews & all); or see if anyone was feeding that system online.
Rebanding will have no effect on EDACS, P25 Standard, or LTR systems. For any of those affected by rebanding, you'd simply enter the new frequencies in the scanner. For EDACS & LTR, those have to be entered in the correct LCN order number, once that is determined, but that's the only issue.
