Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > New User / Getting Started Forum
New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community.
Old 09-15-2009, 12:42 AM
Send a message via MSN to KF5ALO Send a message via Skype™ to KF5ALO
Default Antennas
Since Im living in the dorms on campus, they say that were not allowed external antennas. Are these snoop daddy antennas some magical things?
TUNABLE DESKTOP SNOOP DADDY TELESCOPIC SCANNER ANTENNA - eBay (item 370258357481 end time Oct-10-09 06:46:15 PDT)
Or could I just get one of those window mount antennas and put it on the window of the dorm? I dont think anyone could really see that since theres a tree in front of my window.
Old 09-15-2009, 01:10 AM
No, there's nothing magical about any antenna, especially those. It's just a piece of wire enclosed in a piece of PVC water pipe and painted.
12 volt radios are for wimps. Real radios can kill you.
Old 09-15-2009, 01:18 AM
FLRAILMAN's Avatar
Default Snoop Daddy antenna-gimme a break
My friend, all I can say is this, hold off purchasing that thing until some knowledgeable antenna guys respond to your post & give you a pro or con on it, I read that whole speil & it sounds kinda fishy but I could be wrong. If you cant wait, if I were you & those were the only two options you had, I'd go for the window mount antenna instead, just be patient though, you will get an answer soon enough.
FLRAILMAN
Old 09-15-2009, 11:19 AM
NYRHKY94's Avatar
KF5ALO:
Many of us have had good results running a magnet mount antenna (Larsen and/or Antennex ABSCANC Tri-Band are my top choices) inside. As long as you place the antenna on a metal ground plane like a cookie sheet or file cabinet, you should do fine for your purposes. And depending upon how high-up you are in the dorm, your mileage may even be better than usual.
Thanks - Mike
PSR-600, Pro-106, Pro-2096, Pro-96, Pro-2053, Pro-2052, BCD996T, BC796D, BC898T, BC370CRS, BC210XLT
Listen to my feeds at:
Radio Reference NH
Radio Reference NJ
Old 09-15-2009, 11:07 PM
depending on what you want to hear, you might get by perfectly fine with the regular back of set antenna. we don't know what kind of scanner you have or what you're trying to hear or the conditions of your listening area, so a recommendation is virtually impossible. i do know that a Radioshack 800 mhz rubberduck antenna on a right angle bnc adapter hooked up to my 996 with the radio sitting on a nightstand works fine for 90% of what i want to hear.
A mag mount on a cookie sheet or file cabinet sounds goofy, but it's proven. we've all done that one at some point or another.
Antennas are cheap, no one antenna is best, lots of kinds of antennas are easy to build (completely possible in a dorm room even). you could probably build what you see on that ebay listing quite easily for a few bucks and a little research time if you're even halfway handy.
experiment, don't look for magic wands.
KC9QHR
Plainfield, IL
Old 09-15-2009, 11:28 PM
DPD1's Avatar
One real easy one to do that works fine and won't get female visitors looking at you funny... Just get one of those little BNC clip things with the 15' or so of cable. Put a good hand held antenna on that and clip it in a spot that gets the best reception. Or yo can have a few different ones for different bands. When you're indoors, just moving something a few feet can be a huge difference. With something that small, you can put it anywhere and find the best spot.
Dave
www.DPDProductions.com
Antennas & Accessories for the RF Professional & Radio Hobbyist
Old 09-17-2009, 12:28 PM
Default antennas
as others have stated try a telescopic antenna on your unit,(most base scanners come with one) or my favorite is a radio shack magnetic dual coil antenna stands approx. 3 feet high and works great,
Old 09-17-2009, 01:04 PM
KC9GLG's Avatar
This is an Email that I sent to slinkyantennas asking about the Snoop antennas.
Dear slinkyantennas,
Instead of Bashing your competition, how about a cut-away photo of this amazing antenna you are trying to sell???
Their reply,
Why would you need it?
We don't sell our fine antennas to smart ass CB Greaserz who just got their tech class license!
Besides, you're blocked from our e-mail and from bidding on or buying our products!
When your "post count" reaches 10,000 you get a Bronzed Toilet Plunger from the dollar store ......
The $ sign goes before the numbers............
it's etc................. Not ect.
Old 09-17-2009, 01:27 PM
mrkelso's Avatar
Its just a piece of wire taped to a stick and hot glued at the cap bottom. Then a cap glued on with a hook and some coax and connector.
I made one that looks just like it and hung it up. It works for local stuff and thats about it.
Old 09-17-2009, 01:35 PM
mrkelso's Avatar
A cookie sheet and some mag mounts is all you need.
Old 09-17-2009, 02:11 PM
Their reply,
They sure know how to talk good business don't they...
I'm a scannerholic.
Old 09-21-2009, 04:20 PM
If your dorm room is located on the upper levels of a multi-level building, then you may be in luck and not need another antenna. That's is unless you are overshadowed by even taller buildings. Your problem might not be the inability to receive weak signals, but rather may be having too much interference from the surrounding lighting fixtures, PC noise or front end/IF overloads from nearby transmitting antennas.
