| New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. |
09-27-2009, 08:04 PM
BCD396XT-Problem with uploaded channels
Hello,
I recently purchased a serial port to USB adapter for my Uniden scanner and it is working fine as far as connecting to the scanner & Freescan.
However, when I load the P25 frequencise for my area into the scanner, the scanner shows the frequencies but dosen't receieve them.
Also, I noticed that when I do commit to uploading them into my scanner, none of the memory is used.
Can anyone tell me what setting(s) I might need to change in order to load my local trunked frequencies into this scanner correctly?
Thanks!
City Of Chesterfield In Macomb County, SE Michigan
09-27-2009, 09:48 PM
maybe you need to assign to a scan list? not sure how the unidens work tho
09-27-2009, 10:22 PM
Originally Posted by car7858
Hello,
Thanks!
Want me to send you my file.. we live in the same area?
You can pick your friends, and you can pick your nose, but you can't pick your friends nose!
09-27-2009, 10:23 PM
Sounds good to me, maybe someone will come through this post and tell me how to assign them to a scan list.
I deleted the original frequencies that I had from my local area (Macomb County, Michigan), thinking that when I uploaded them the second time I would have an updated list.
09-27-2009, 10:24 PM
Use my file above..
09-27-2009, 10:29 PM
Hello Rocksteady, good to hear from you again.
I can load the right frequencies into the scanner and the scanner shows that they are in there, but I don't receive any calls at all, even though the scanner is searching through those banks listed under macomb County.
I still need to download a WinRar license as I wouldn't be able to unzip those files you sent me without it.
I believe the problem is a particular setting in the Uniden BCD396XT itself that must have been mistakenly altered enough to stop those channels from loading into my scanners' memory, again even though they do show when I manually search them.
09-27-2009, 10:30 PM
pm your e-mail to me. i'll send it unzipped.. make sure control channel does not have a check in it too....
09-27-2009, 10:33 PM
OK I will send email to you and check control channel settings. Thanks a bunch!
Make sure it's unchecked.
09-27-2009, 10:36 PM
Ok, that control channel option is under the Settings tab in the scanner, correct?
09-27-2009, 10:38 PM
Under each system settings..
09-27-2009, 10:44 PM
The only place I see anything sim ilar to control channel is under the Settings tab, where it says C-Ch Output; Should I set that to Off?
09-27-2009, 11:08 PM
Rocksteady,
Allright, thanks to your info and help, my scanner is working fine and I am impressed with the way you made the alpha tags more understandable, not to mention the different color schemes for certain locales. Thanks a bunch & I'm certain that when I need info & maybe some accessories in the near future, I will be in touch with you.
Man, even the sound (reception) is 100% better!
Can't beat this Radio Reference forum!
09-27-2009, 11:11 PM
Any time I can help anyone, I will. This forum has been a great resource for me. I hope that I can help out my fellow scanner friends whenever I can.
Rocky
