Welcome to RR.com,
kellec4. You are in for an abrupt wake-up call. Gone are the "plug n play" days of scanning. Today's scanners are mini computers with a Central Processing Unit and the whole nine yards and your scanner is at the top of the line. You can no longer just turn it on and listen. You are going to need to study so you can understand new concepts. I recommend you begin with
Trunking Basics. (Anything in blue and underlined is a clickable link.)
Originally Posted by kellec4
Just got a new digital scanner (pro 197). I know zero about these new digital scanner tech and have a few questions.
1. Just curious what the decimal format means. My city is digital and when looking up frequency on this site, I see this under "DEC"---"this is the talkgroup in the decimal format. Decimal format is used for programming"---------what does this mean and how do I put those codes (ex. 25648) in? I would like to listen to specific frequencies until I get the thing programmed. I am used to an old (10 years) scanner from radio shack that you simply scan or punch-in a specific freq.
Instead of using frequencies to hear your favorite agencies, you listen to Talk Groups (TGs). These TGs are identified by a DEC notation (that means Decimal) which humans understand more readily. They can also be identified in HEX notation (Hexadecimal) which the scanner understands but is difficult for humans to identify without a calculator, so DEC format is the one used almost exclusively.
Once you understand Trunking, you will see what I'm talking about.
2. A more broad question. What do I need and how do I, program this scanner?
Sorry for being ignorant on this subject but I need help.
Do not be sorry for not knowing this stuff. It is heavy. No one will fault you for asking questions, but you must ask informed questions which means you need to do some studying. You will never be ridiculed for ANY question you ask, however. There are people here that are ready, willing, and very able to answer your questions. Read your owner's manual to get as much information as possible. There is an
easier to read manual here that may help.
You can program your scanner manually, but that is very tedious. It is strongly recommended that you get a programming cable (
the 20-047 cable from RS, or
the 30-3290 cable from GRE).
You should also get programming software.
You will find the software recommended here:
- WIN500 (My personal favorite)
- PSREdit500
- ARC Software by Butel
All the software offered have a 30-day trial free trial period so you can try each one and select the one that best suits your needs.
In order to access the RR Database through your software, you will need a
Premium Subscription to RR.com.
If you should decide to use WIN500 (my recommendation), you will find
an illustrated "tutorial" with step-by-step instructions here to help you program your scanner.
Again, welcome. There is a lot of information on this Web site. Explore it and find out what is available, study, and ask questions.
