Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > New User / Getting Started Forum
New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community.
Old 10-12-2009, 11:41 PM
Default need help programing pro 2096
I cant figure out how to program from radio ref to my scanner. I can acess freq. but cant figure out how to channel them to my scanner.
any help would be apprciated.
thanks
Old 10-13-2009, 05:46 AM
Wiki Admin
What do you mean 'channel them to my scanner'? Do you mean that you need help in uploading to the scanner? Are you using Win96 or ARC96? Do you already have a USB-serial connection between the scanner and PC (since most newer PCs have no serial ports)? Are you trying to program Fleetnet - and if you are, did you follow these instructions (from our wiki - note that here, and in the wiki, anything in blue is a link)...
Programming your Pro-96/2096 for Fleetnet - The RadioReference Wiki
More information, please...73 Mike
Old 10-13-2009, 10:15 AM
fmon's Avatar
It's the OP's first post and with premium subscription the question may be "how to load from database to scanner".
paddyo, if that is the issue, you will need software and a programming cable. Win96 from Software for RadioShack PRO-series (PRO-92, 93, 95, 96, 97, 99, 163, 164, 106, 197) and GRE PSR-series (PSR-500, 600, 300, 400) scanners is the best software and use cable 20-047 from RadioShack.com This cable should be in your local RS store on the Michigan side.
Frank
RR Wiki Programming Shortcuts
Old 10-13-2009, 03:28 PM
Tks for getting back to me. The trouble im having seems to be with the web input page. ie. target bank?, bank name?, first target chanel?, first talk group sub bank?, first talk group and so on.
I can find the freq i want and i have the proper cable ti upload them into the scanner but when i do not a lot happens because i dont knoe how to deal with the above?
Tks again for taking the time to repond
paddyo
Old 10-13-2009, 04:33 PM
that is asking which of the 10 banks you want to put the freqs in & which channel to start on & which talk groups you want to put in that bank ( limit per bank is 150 in 5 subgroups of 30 each.
if you need a manual send me a PM with email & can send you a PDF copy.
Paul
Old 10-13-2009, 05:24 PM
fmon's Avatar
paddyo, I realize you are new but you need to give us more info. Are you using software, if so, which software?
If Win96, view this image. The two Sault frequencies are upper left and the 149 talkgroups are on right side. You can click the bullets in:
0 (currently checked).
3
4
to view other talkgroups which are 30 per sub-bank 0 through 4.
I've also opened the Extended Trunking Tables dialog for viewing.
Frank
Old 10-13-2009, 10:50 PM
mciupa's Avatar
Looking at fmon's attached image select 3600 CC VHF for Fleetnet Standard Plan and also band plans #00 ,01,02
You can put as many towers in one bank as you wish, be sure to separate each control channel with an FM mode freq. in the channel prior to you control channels.
I do this for three towers on Fleetnet.
I hand programmed my 2096.
