Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 03-03-2010, 2:43 PM
jp2code's Avatar
Default Antenna Rotor Power
Hi. Newbie here.
I took an antenna down from a neighbor's house this past weekend that had not been used in 10 years.
It had a rotor on it, and I'd like to test it out to see if it works. The controller for the rotor is no longer a part of the home, so all I have is the exterior motor.
What kind of power do these take? 110V AC? 12V DC? How would I identify a manufacturer? I can't see any markings on it, and from what I've found online most new ones don't either.
I appreciate your time,
~Joe
Old 03-03-2010, 10:38 PM
Originally Posted by jp2code View Post
Hi. Newbie here.
~Joe
Maybe if you post a picture if it and see if anyone here can identify it.
A lot of TV rotators operate on around 24VAC, and frequently require a starting capacitor, so you can't just hook a power source up to it and expect it to run.
Keepest thou thy airspeed, lest the ground rise up and smite thee.
Old 03-04-2010, 7:49 AM
jp2code's Avatar
I don't really want to keep it. My dad is trying to give me an old controller that he has, but I'd rather not have the hassle of turning an antenna to pick up a signal.
I just want to verify that it works before I put it on eBay or Craig's List.
I'll see about getting a picture for the members to look at, though. Stay tuned!
Old 03-05-2010, 8:41 AM
jp2code's Avatar
Images of the rotor assembly are attached.
Numbers on the unit shown in P1010107.JPG are 12898 (bottom), Y1-8 (middle), 98 (middle-right, I guess that's the year), 13208 on the neck as shown in P1010109.JPG.
Could someone help me identify this item? I want to try applying power to see if it works, but I don't know what voltages to use or what wires are positive, negative, and ground (DC) or common, neutral, and ground (AC).
~Joe
Avoid Sears Home Improvement!
Old 03-05-2010, 9:19 AM
wb0wao's Avatar
That appears to be the standard Radio Shack light duty rotor that they sold for years. I have had a couple of them and they are useable but have a tendancy to "drift" a bit, so you have to re-sync them periodically. IIRC, they use a three wire control cable.
Dennis
BCD996P2/BCD325P2/PSR-410/WS1098
Cape Girardeau Area Monitoring Blog
capescan.blogspot.com
GMRS -- WQWR852
Old 03-05-2010, 9:28 AM
jp2code's Avatar
Figures. Probably not worth trying to sell then.
Any idea on what kind of power it takes? 110V AC? 24V DC?
~Joe
Old 03-05-2010, 10:07 AM
Default Power
I believe they use 24 V AC, not DC. Almost all antenna rotors use low voltage AC for safety reasons.
