Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 05-13-2011, 11:06 AM
kenn_moses's Avatar
Default Project 25 standard vs. single channel trunking
I am trying to decide between the PSR-600 and the BCD996XT. One of the trunked systems I am interested in is the State of Colorado DTRS. The system in Mesa County is identified as:
System Type: Project 25 Phase I (FDMA)
System Voice: APCO-25 Common Air Interface Exclusive
I note that the GRE PSR-600 does not do Project 25 Singe Channel Trunking but the BCD996XT does. How can I determine which scanner I need or put another way...how can I tell if the state system uses "Single Channel Trunking" thereby eliminating the PSR-600?
Thank you.
Kenn
Old 05-13-2011, 1:11 PM
mikey60's Avatar
Thank you.
Kenn
The DTRS system in Colorado does not use single channel trunking. All sites are multi-channel trunked with control channel. Both models will work on that system.
http://www.psredit.com
Old 05-13-2011, 5:39 PM
kenn_moses's Avatar
Thank you so much. Your response is very much appreciated!
kenn
Old 05-14-2011, 9:42 PM
Default Which end is up?
Please delete this
Old 05-15-2011, 9:46 AM
ecps92's Avatar
Single Channel trunking is for those who want to monitor a P25 Single Conventional Frequency and track the Radio ID's of the users.
It's not used for Trunking, but only to log Radio ID's which the Trunking systems will do. For someone interested in just trunking, it should not be a deal breaker if it doesn't have that feature.
Thank you.
Kenn
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
