Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > New User / Getting Started Forum
New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you.
Old 01-04-2012, 5:22 PM
Default Scannercast setup with HP T5710 Thin client
Hi everyone! I've got a small issue regarding using Scannercast with my thin client. I previously was running Scannercast through my desktop and recently picked up a T5710 to run my Magicjack and Scannercast on so I could shut my desktop down at night. I've gone through all of the settings trying to figure out how to do the sound capture, but haven't had any luck with it actually working. The scanner is connected to the mic jack on the client, but Scannercast doesn't list the mic as an option for sound capture. It lists the primary sound capture device, the Ali Audio Wave, and my magicjack as options. Of course MJ won't work, but neither do the other 2 devices.
Any thoughts on how to configure this? My microphone is enabled, and not muted, yet I cannot get it to transmit the broadcasts like it should. Everything worked fine through my desktop using the line in jack.
Thanks!
Phil
Old 01-12-2012, 2:08 PM
All is good. I thought it wasn't streaming to RR, but it is.
