Worng Firmware ??
There is 2 different firmware update file available depending if you own a Canadian or American version. I made the same mistake last weekend because I own a PSR600 (American) and a PSR500C (C for Canadian) and went with both American firmware. When trying to update the 500 with the American firmware it did the same as describe in your post ... Then I used the "c" version and it went smooth.
The file you describe seems to be the American version especialy because it says v2.1 in your description and the Canadian version is only at v2.0 ... See the print screen attachment from the GRECOM site.. It seems V2.1 is not available or not necessary on the Canadian version The release notes for the V2.1 version says "New in version 2.1 • Fixed Marine, VHF, and UHF search frequencies"
Do you own a Canadian or American PSR500 ? To find out, go on the back label of the PSR-500, you will find the answer right next to the "GRECOM" name. On mine it's written PSR-500 C
Slypx
Quebec DB Admin
BCD396XT | PSR600 | PSR500C | BC780XLT | PRO2006 | PRO2046 |
