Originally Posted by ST-Bob
The Philadelphia Police use digital P25 for most things. You will need a digital-capable scanner such as a Pro-106/Pro-197 or a Uniden 396-XT or 996XT or a PSR-600 which does digital. The price of entry for these is pretty steep but that's what you need for digital - a $400-$600 scanner.
Keep in mind that the Pro197 and the BC996XT are base scanners, so they would not be ideal for moving around. Personally I like the BC396XT. Scanner master has some sales for the holiday on 396. One come with a
case and hometown programming and the other comes with
software, programming cable and an easier to read manual. Those would be a good way to start off, that way you have everything you need to get started. I personally recommend the second option. That way you can make changes to it as frequently as you want. It is not too hard to program, especially if you have a RR premium membership.
Those are both great deals at $499.99 because the scanner alone is normally $439.99 so for $40 more you get a lot more. Plus, enter the cupon code "freeship50" and any order over $50 will ship for free.
