Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > New User / Getting Started Forum
New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you.
Old 12-30-2012, 11:20 AM
Default Can you listen to a specific frequency
New user here (signed up today)....... There is a feed with multiple PD and FD departments all in one. Is there a way to just enter a specific frequency and listen to just that?
Old 12-30-2012, 11:27 PM
W8RMH's Avatar
No. There is no way to modify what is being streamed.
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
Columbus Police Citywide Dispatch
Old 12-31-2012, 2:06 AM
krokus's Avatar
The feed gets what it gets. If you can find someone that just listens to the one freq, and they are willing to stream it, then you can get what you want.
Old 12-31-2012, 3:28 AM
As others have said, you can only listen to what the volunteers are providing. However keep in mind that some providers are streaming in stereo. I know that some feed providers will separate police and fire calls by putting one on the left channel and the other on the right channel. So while you can't select just one frequency to monitor, you may be able to eliminate some traffic by turning off one or the other speaker.
Old 01-05-2013, 8:18 AM
Someone educate me - just what kind of feed is been talked about here: is it analog or digital, how are the different transmissions combined/multiplexed into the feed, and how are they seperated on the reception end for the respective parties?
Old 01-05-2013, 8:22 AM
n7lxi's Avatar
A "feed" is created when a scanner owner takes the audio output of his scanner and broadcasts it to listeners via the Internet.
The listener has no control over what the scanner owner chooses to monitor and broadcast.
It would be the same if you called me on the phone and I put my phone down next to the scanner so you could listen.
Sent from my iPhone using Tapatalk. Sorry for any spelling errors.
"If it can't be expressed in figures, it is not science; it is opinion.” -Lazarus Long
Old 01-06-2013, 1:22 AM
W8RMH's Avatar
The audio from two different scanners is streamed, in stereo, to RadioReference / Broadcastify which then streams the feed in stereo over the internet, one radio on the left channel, one radio on the right channel.
You can listen to both sides simultaneously in a normal volume setting, or adjust your left and right volume controls to listen to just one side at a time.
The fact that it is analog or digital doesn't matter.
Here is an example of a stereo feed.
Old 01-06-2013, 2:59 AM
Got it - all clear now: that folk were talking about an IP format through a website didn't register with me.
Thank you.
Old 01-06-2013, 9:18 AM
xxdanielt3's Avatar
You could purchase your own scanner and program the frequencies you want to.
RadioShack Pro-164 - Uniden BC95XLT - Motorola Minitor III - Kenwood TK-3302U - Baofeng UV5R - Minitor II - (2) Minitor V
Old 01-07-2013, 2:45 AM
W8RMH's Avatar
Of course this will only work if the OP wanted to monitor local agencies.
There are many live feed listeners who listen to feeds well outside their local area.
