Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > New User / Getting Started Forum
New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you.
Old 01-09-2013, 11:00 AM
Default Banks
While programming my radio I was attempting to separate police from fire in my area using different banks. I now realize that they use many of the same frequencies and its just a jumble regardless of the banks. Is there any way to seperate them so I can focus on just one?
Old 01-09-2013, 11:17 AM
It would be very helpful to tell us:
What scanner you are using... (older scanners use "banks", some newer ones don't)
Where you are and exactly what you are trying to listen to...
Are you manually programming or using software...
If using software, which one?
We can give you much better help with that info.
Old 01-09-2013, 11:36 AM
I have a Pro 528 RadioShack Scanner. I live in Las Vegas NV and I am using Radio Reference and transferring the Data using the usb cable. I am trying to listen to Henderson Fire and Henderson Police and Nevada Highway Patrol. I appreciate assistance
Old 01-09-2013, 12:15 PM
N8IAA's Avatar
I'm going to presume that you are listening to the SNACC system on your scanner. To have PD and FD in separate banks, You'll need to program each bank with the Henderson trunking frequencies and input the TGID's for the PD/FD into the separate banks. Then you can turn the banks on and off at your pleasure
HTH,
Larry
Digital/Analog scanning and hamming
Old 01-09-2013, 5:40 PM
DickH's Avatar
That system has been rebanded. The PRO-528 can not follow rebanded freqs. (freqs. that have a zero in the 4th decimal place, like 851.3500). You can enter all the freqs. into your scanner but you will hear only parts of conversations.
Dick H
http://dickh.zenfolio.com
Old 01-09-2013, 6:02 PM
Highpockets's Avatar
Send a message via AIM to Highpockets
If this is the system he's listening to and he's using the Henderson site, it may not be re-banded yet, if so the database wasn't updated.
Clark County - Southern Nevada Area Communications Council (SNACC) Trunking System, Clark County, Nevada - Scanner Frequencies
Steve
BC785D ~ BCD396XT ~ BCD996XT ~ PSR600
Old 01-10-2013, 8:23 AM
DickH's Avatar
If you looked at the Henderson site you would see that every freq. is a rebanded freq.
Dick H
Old 01-10-2013, 12:30 PM
Chauffeur6's Avatar
DB Admin
The Henderson site shows 866-868 frequencies, which are not rebanded frequencies. Take a look at the Site Details page, the rebanded flag is not set for that site. Highpockets is correct.
Lake Las Vegas - Henderson Site Details (Clark County - Southern Nevada Area Communications Council (SNACC))
The correct post-rebanding frequencies for that site would be:
851.275
851.775
852.050
852.800
853.950
Old 01-13-2013, 8:08 PM
DickH's Avatar
Are you sure they are using that site? This one seems to be current.
Dick H
Old 01-13-2013, 8:11 PM
Chauffeur6's Avatar
DB Admin
I had the same thought as you, that they may've abandoned that "Lake Las Vegas - Henderson" site. I couldn't find any direct match for it on any of their current licenses. That may also explain why it's still in the RRDB with all the pre-rebanding frequencies. Probably something for one of the local admins to take a look at, and to delete that site if it's no longer valid.
