Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > New User / Getting Started Forum
New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you.
Old 01-24-2013, 12:30 PM
alfonzo1955's Avatar
Default Need Cheap Scanner for UniTrunker
I need a cheap scanner that can listen on 800MHz and is able to be hooked up to UniTrunker so it can drive my PSR-310 to listen to ProVoice. Any ideas?
Cheap Scanner -> UniTrunker -> PSR-310 -> DSD
Old 01-24-2013, 2:28 PM
scancapecod's Avatar
ScanNewEngland Webmaster
Send a message via Yahoo to scancapecod
If you're computer savvy you can actually do this for under $60. Do a search here and via Google for RTL2832U. In a nutshell you'll need two RTL2832U dongles (R820T preferred), SDRSharp software which is free, the modified version of SDRSharp that is integrated with UniTrunker, DSD software which as you know is free, and a registered version of Virtual Audio Cable to transfer the unfiltered audio from the modified SDRSharp to UniTrunker...and finally of course, UniTrunker.
Or....one of the RTL2832U dongles and VAC would work fine to drive your PSR310.
Scott - Scan New England Webmaster
http://www.scan-ne.net
Radio Reference MA, RI, & CT Database Admin
Old 01-24-2013, 3:20 PM
bgav's Avatar
Yup, works great, a little bit of work setting up using this great guide but not too difficult. My impression was the ones with E4000 are preferred over the ones with R820T chipsets with the exception of use for ADS-B. Scott - You might recognized the traffic below!
HP-1|PSR-800|BC780XLT|Pro-92
PlanePlotter Ground Station ya
Old 01-24-2013, 4:52 PM
Is there any way for me to do this under Linux?
Tags
cheap, psr, psr-310
