Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > New User / Getting Started Forum
New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you.
Old 01-26-2013, 9:07 AM
Default Interruptions in transmissions...
Hi all!
When I listen to my local PD / Fire transmissions, every broadcast is interrupted with a steady (every 1 sec or so) pattern of silence throughout the transmission. I get most of the conversation, but it's irritating to have momentary interruptions. The interruptions occur in a regular pattern and last only a moment. I use both a BCT15X and a handheld Bearcat. Both do the same thing.
Any ideas what might be going on?
Thanks in advance!
Jamie
Old 01-26-2013, 7:29 PM
W8RMH's Avatar
Sounds like you have either priority or close call selected.
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
Columbus Police Citywide Dispatch
Old 01-26-2013, 8:25 PM
Blackink's Avatar
Default Maybe This?
Having Beartracker enabled will do the same thing also.
Have you read any of Mark's "Easier to Read" scanner manuals?
Clicking-here will get you to the site.
Good Luck
Steve in Vermont
I own a BCT15X.......and I Love it
Old 01-27-2013, 8:39 AM
Rt169Radio's Avatar
Is the WX priority feature on?
Old 01-27-2013, 8:51 AM
Your radio is reverting to some kind of priority channel you or someone else has set into the program. Find the priority setup and disable it and the program will then stop its jumping back to see if anything is going on in the priority channel's location. Some radios display a ""P" to indicate that the radio is scanning for a priority signal.
