The HP-1 can handle rectangles now. What we'll need to change is the process that pulls the data from RadioReference (once it is implemented on this site). In the mean time, you can define rectangular coverage zones fpr systems you've put in Favorites Lists right now. Probably not practical for a extended drive, right now, but certainly desirable if you are moving around a metro area. I did some remapping of the DFW area to rectangles (had to for testing during development), and it works quite well.
Addressing a couple of other things mentioned above:
We start the data pull Sunday evening at 6 pm. So, if data in Alaska, Alabama, etc changes after 6 pm, it won't make it into that update. If Wyoming, Wisconsin, etc are updated, you probably have until the wee hours of the morning to get the update in and still make the load. When someone notifies me that a major system got an important update (rebanding, for example), I'll trigger an off-cycle pull so you won't have to wait a week for the update.
As for traveling solutions: I amplify the above recommendations as to using the HomePatrol-1 coupled to a GPS. It is truly "set and forget." The other scanners are great, but they also have a great big learning curve that will likely destroy all the fun of listening. (Despite what I do for a living, programming scanners is not something I particularly enjoy...rather it is a necessary evil.)
Post #1 you ask:
Do the frequency data files available through this site already contain location information that a GPS-enabled scanner can understand, or would that need to be added in manually?
RadioReference's database already has location tags (in latititude, longitude, range format) for everything. However, "frequency data files" are not particularly available...what is available is a SOAP interface that allows you to send queries to the database which the returns data based on your query. Scanner software (like ARC, Freescan, etc) as well as our process to do a full database pull weekly takes advantage of this interface.
b) In my research I came across a number of in-car setups that use *BOTH* the BCD996XT and the BCT-15. Why would I need both of these at the same time?
Because more (especially Uniden) scanners is always better.
c) Is it reasonable to store an entire 3500mi road trip passing through several major metro areas in the scanner at one time? Would the scanner's performance improve if, for example, we took a laptop and only loaded the next day worth of frequencies at every night stop?
Other than the HomePatrol-1, no GPS capable scanner has the memory capacity to store all the radio systems you would encounter on such a trip. That said, on the BCD396XT/996XT models, of course the fewer location-based systems enabled at any time, the better. The scanners try to reselect in real time, but give priority to actual scanning functions. Too many LBS active at one time will "bog down" reselection latency (you'd notice it being slow to turn on/off systems that should be turned on/off as you change location). HomePatrol-1 provides a seamless experience and has a few more horses under the hood, so this latency is minimal.
