Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > New User / Getting Started Forum
New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you.
Old 03-06-2013, 3:35 PM
Default USB Sound Cards
Are these USB Sound Cards any good? The reviews I have read say otherwise.
I want to use one for a Discriminator tap.
New USB 2 0 to 3D Audio Sound Card Adapter External Virtual 5 1 | eBay
Are these any better?
http://www.ebay.com/itm/USB-6-Channe...item19d2678c29
I like this one more because it have a line-in port. Do I need that or can I use the MIC-In just as well?
Old 03-06-2013, 3:54 PM
dcr_inc's Avatar
I use them on one of my 4 feeds.. They work good but you may need to attenuate the input from the scanner to prevent distortion. Listen to the Harford County Maryland Fire, EMS and police feed on broadcastify.com if you want to hear one live. It is being fed from the line output jack on a HP-1 scanner
PSR800 2 , PSR600, PSR500, PRO2096, PRO106, BCD 296D P25 card, Commercial FCC license, Ham General, FAA Private Pilot, Business Owner, APCO Certified Tech.
Old 03-06-2013, 3:56 PM
dcr_inc's Avatar
I was referring to the USB audio cards not the optical USB interface in the last post
Old 03-13-2013, 2:54 AM
xeno194's Avatar
USB sound cards are ok. I would pickup a handful of them cause they do tend to just stop working for no reason. You will need to shut off the mic input gain setting via the sound settings/recording properties. If you not running a feed I would just consider using r820t sdr for disc audio via SDR#
rtl2832u r820t SDR - YouTube
996T/RTLSDR/BC244CLT X3/UV3R+/UV-5RE/Afedri SDR Net
http://www.mikexeno.com
Old 03-13-2013, 7:38 PM
I have one and have terrible performance, everything's very weak.
RTL-2832 Help
Can you give me some advise and tell me your setup.
Old 03-13-2013, 8:21 PM
mancow's Avatar
I have a few and they are great.
Old 03-13-2013, 9:41 PM
n7lxi's Avatar
I have several. They work fine.
Sent from my iPhone using Tapatalk. Sorry for any spelling errors.
"If it can't be expressed in figures, it is not science; it is opinion.” -Lazarus Long
Old 03-14-2013, 2:08 AM
xeno194's Avatar
My setup is here.
Mike Xeno: SHACK
Do you have the gain setup properly and what app are you using? sdrsharp or hdsdr also what antenna are you using on the 820t
Old 03-15-2013, 4:02 PM
My setup is here.
Mike Xeno: SHACK
Im using SDR Sharp and I have the gain set to the Maximum.
Old 03-15-2013, 10:22 PM
xeno194's Avatar
See if my settings help
