Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > New User / Getting Started Forum
New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you.
Old 03-06-2013, 4:37 PM
mrnavy2's Avatar
Location: Ocean Twp, Monmouth County, Central New Jersey
Send a message via AIM to mrnavy2 Send a message via Skype™ to mrnavy2
Default BCT15X
Hello all, 1st time posting here. My question. I am thinking about purchasing the BCT15X and i m going to have Scanner Master program it for me for my country. I would like to know of you can tell me the Pros and Cons on this unit? I am now using the Pro 79. So o k.ow it is time to.upgrade to something much better. Thanks for your help. Steve.
Old 03-07-2013, 12:04 PM
Wiki Admin Emeritus
While the 15X is a very good scanner, it doesn't handle digital systems - and that's a growing topic, even in Central NJ (where in NJ - I'm from Northern NJ myself)?.
I'd go and make yourself familiar with the database and wiki for your area. Go to the NJ forum and ask questions - let the locals guide you, as they know their own systems well.
New Jersey Radio Discussion Forum - The RadioReference.com Forums
Old 03-07-2013, 7:12 PM
mrnavy2's Avatar
Mike, thanks for the quick reply. I am in Ocean Twp, between Asbury Park and Eatontown. I am new to this forum so I to learn a lot. I will go to New Jersey forum. Thanks and keep on touch. Steve..
Old 03-07-2013, 7:52 PM
ZFD22's Avatar
It does handle DPL )Digital PL Tones) Extremely well
Old 03-07-2013, 8:38 PM
WAScanMan's Avatar
Send a message via Skype™ to WAScanMan
It's my favorite non-digital scanner. I use mine for basically everything a scanner could be used for. I also have the handheld version which is good but not as good and doesn't have the 225-400MHz milair range. If you end up needing a digital scanner I'd go for the 996XT. It's essentially the 15X but it'll do digital. Also, I recommend using the supplied cable (or purchase the USB cable if you don't have a serial port) and some of the free software avalible to program the unit yourself. It's a breeze with a subscription to RadioReference and it'll be helpful to learn for future use. Plus, you can add and remove what you want from the scanner, whereas if you get it pre-programmed you're limited by what they add.
Pro-97 | Pro-106 | Pro-107 | Pro-508 | BCT15X | BC346XT | Satellit 750 | S450DLX
Old 03-08-2013, 11:20 AM
mrnavy2's Avatar
Well Gents, I just order mine from ScannerMaster. I also order the Pro CD, 180 days script for RR, and the USB connected. So when i get it next week i hope you all will be around to help me get it program. As WAScamMan stated it would be better that i learn how to do it myself. So, I have a few days to read up about RR and also to activate my account... Any info you think i will need please feel free to let me know.. Thanks all again, Steve, Ocean Twp, Monmouth County, New Jersey..
