Hi, just purchased a Radio Shack PRO-2018 Scanner, and having trouble locating the frequency for my home town. I live in Rowlett, Texas and when I go to the list it says trunked system with Garland. Have no clue what tht means....any help would be appreciated. I am a very old newbie.
Hi Barnum
Welcome to RadioReference
As the others have noted, the Pro-2018 is not capable of monitoring a trunked radio system. Besides the link Jeff has provided, this Wiki
page has links to other articles on the subject, to give you a basic idea of how these radio systems work. Be sure and read this
article.
The
Garland system, which includes Rowlett, is analog. As Tahoe1970 noted, that's a rebanded system, so any scanner used for listening to this system must be 'rebanding friendly'. Otherwise, the system will not track correctly and you'll miss just about all of the radio traffic.
Unfortunately, your new scanner won't work for the system in use in your area. It looks like a basic analog trunking scanner would work for you, for now. You should be able to get into an adequate scanner for under $200. I would also caution that several systems are migrating to digital modulation(p25). I believe Tx DPS is using p25 digital. Other than DPS, most everything around Dallas appears to be analog. FYI, a digital capable scanner would usually run around $400.
(snip)
Hope this helps,
Jeff.
While an analog trunk-tracker would work, for now, for Rowlett & the Garland system, there is actually quite a bit of digital use in the Dallas/Garland area, and slowly, but steadily increasing.
Texas DPS, as noted, is digital using conventional frequencies. (The Region 1 office and communications center is on I-30 in Garland, just to the S/W of Rowlett.)
Richardson, which is just to the west-northwest of Rowlett, has migrated to a new P25
system.
Wylie, which is just to the north of Rowlett, Plano (slightly northwest), and others are on the
PAWM P25 system.
Dallas (city) is still on Uhf conventional, but long term, will likely move to a P25 system. The question here is whether this will become a 'regional', Dallas County area, system, with other entities participating, or mainly City of Dallas only.
So, for the time being, a good, rebanding friendly, analog trunk-tracker would work specifically for Garland & Rowlett (it would also handle Rockwall County & the Rockwall (city) EDACS trunked system). However, if you also want TX DPS, Plano/Wylie, and/or Richardson, you'd need to get a digital trunk-tracker.
