Is there a way to delete all programmed channels or to return the scanner to default settings?
Also, you'll get a prompt on the scanner, asking if you want to restore the original preloaded frequencies. You don't. The data stored in the scanner is wayout of date.Press 2 and 9 and hold buttons while it is off, then continue to hold them down and turn the scanner on. The screen will ask confirm reset? Press E/yes
Also, you'll get a prompt on the scanner, asking if you want to restore the original preloaded frequencies. You don't. The data stored in the scanner is way out of date.
now that I have a group programmed, how do I scan just that group?
Is there any way to also display the frequency?
For the 996T (but not the 396T), you do have the option of display modes.For conventional frequencies press New Channel, input the frequency, press Edit Name and type a short alpha tag right after the frequency, deleting “MHz” if necessary. Moving the frequency one space to the left and deleting any zeroes at the end will free up even more space. You can also come up with your own set of abbreviations.
If someone knows a way to enable other display options in the 996T I hope they will enlighten us. Some older radios (such as the BC780XLT) have a generous amount of space for the alpha tag which displays underneath the frequency so that both are shown together.
Tap the Scroll knob to activate the Function mode, then press the 0 (zero) to toggle between Display Modes 1 & 2.
That's on page 51 of the *.pdf manual, found here.
What you ned to do is assign each system a unique quick key. By 'unique', I mean that the key assigned (you can use any number from 0 through 99) should be different than the other systems. The exception to that might be where a given city, county, or agency used both conventional frequencies and a trunked system. In that case, you might want to assign the same key number to both the conventional system (for that collection of frequencies) as well as their related trunked system.I know I'm probably becoming a pest about my 996T but I still need help. Is there a way to choose to scan between systems?
