rustymac01
I am about to install a Scanner Antenna in my Attic. Does an indoor antenna need to be grounded the same as an outdoor antenna?
rustymac01 said:I am about to install a Scanner Antenna in my Attic. Does an indoor antenna need to be grounded the same as an outdoor antenna?
So static electricity doesn't build up in the coax if the antenna is mounted/placed inside a structure compared to placing/mounting it outside?
I've read many posts in these forums suggesting a ground block/grounding wire should be installed due to static electricity build up in the coax.
I'm curious to know the answer.....
The NEC (National Electrical Code) requires that the shield (braid) of ALL coax entering your house to be grounded. This is conveniently done using a grounding block connected to your main electrical ground or if more than 20 feet away from the main electrical ground a ground rod driven in the ground. In either case all grounds (and ground rods) need to be connected to the main electrical ground. See section 810 of the National Electrical Code.
BB
