If you have not created channels that use those service tags, and loaded those channels in the current channels, then they will remain greyed out. The scanner only allows you to select service tags that are used by some channel in the current load.
Canadian nationwide services are only available to scan if you've set your location to be inside (or near the border of) Canada. You would not be able to hear any of those channels from Florida...
