Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > New User / Getting Started Forum
New User / Getting Started Forum The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you.
Old 12-14-2013, 2:58 PM
Default new to scanners
hi to all , I am sure this has probably been asked but , I am waiting on a new bct 15x from scanner master I want to mount an antenna on the side of my shop.the shop is all metal siding and roof -question is how high above the roof line should the antenna be?I have a inexpensive radio shack discone type antenna and rg58 cable.Wee live up on the side of a mountain in the woods at about 3100 elevation in Stevens county WA.I will probably upgrade to a better antenna if I need to but this hopefully will get me started! The scanner is coming pre-programmed being that I am a not at all computer or scanner smart! ANy help or ideas are great! thanks again !
Old 12-14-2013, 7:22 PM
Blackink's Avatar
I have a ST2 antenna mounted about 12 feet above the peak on my metal roof and it works great. My house has vinyl siding but the roof with a 4-12 pitch has metal. The antenna is mounted on one end of the house.
I too have a BCT15x so I'm sure you'll enjoy yours.
Steve in Vermont
I own a BCT15X.......and I Love it
FreeScan User
ST-2 Antenna by Antennacraft
Old 12-14-2013, 7:27 PM
N8IAA's Avatar
Welcome to RR! The discone should do well with the scanner. The antenna should clear the roof by the bottom of the discone ( the ground plane radials). RG-58 should be good for the frequencies you will be monitoring. Don't go over 100' on the coax. 50' or less is better.
Let us know what happens when it's set up.
Larry
Digital/Analog scanning and hamming
Old 12-15-2013, 3:51 PM
Thumbs up new scanner
thanks all I will go above the roof peak by 2 or 3 feet. I am building my own mount and mast out of alumminum, I have a copper ground rod to drive in the ground but will have to wait till spring since we are frozen up here! may be able to get something in the ground that will work till then!I will keep ya'll posted on how it all works!thanks again
Old 12-15-2013, 7:24 PM
N8IAA's Avatar
Try a tripod attached to some plywood. The mast should at least take you up above the metal sides of the shed.
HTH,
Larry
Old 12-15-2013, 7:55 PM
wtp wtp is offline
Default why wait
when i moved to florida, i just sat my rs discone on the ground for a few hours and could pick up a sat on 150.0 mhz. and when left alone at my house it sat as a sick christmas tree on my dining room table. so try to enjoy it now. when i bought it i was in new jersey 1980somthing i caught a florida 27mhz football relay to an a.m. radio station. no rules to receive so try anything
enjoy.
Old 12-16-2013, 5:52 PM
pdfdems286's Avatar
i think 150.000 is a russian orbiting satellite. you can probably pick it up anywhere. i have in n.j.
drooling is a problem that can be licked !
Old 12-19-2013, 1:15 PM
Thumbs up new scanner up and runnin!!
Well I got it off the ups truck and after mounting the antenna,{had to convince the "war dept" to come hold the ladder] got the coax on an turned it on -so far so good.reception is very clear and good ! Not gonna touch any buttons as I am stilll reading the user guide and looking at the cd- they sent with the scanner, Programming seems to all be there-police sheriff,fire DOT and county maintainence. we got weather movin in so that ought to pick up the traffic a little bit. colville out!
Old 12-19-2013, 3:08 PM
wtp wtp is offline
Default excellent
good to hear !
Old 12-19-2013, 3:19 PM
russellmaher's Avatar
Hello colvillegreg and welcome to RR.
It sounds like you're having a good time with the new scanner already.
Hope it provides you with many hours of enjoyment.
Russell
SEMPER PARATUS
BCD396T BCT-7 BCD350C PRO-2052 ICOM R-75 BC175XL REGENCY R-1050
Old 12-19-2013, 4:34 PM
Blackink's Avatar
I'm glad you got it all working.
It's nice when everything comes together and works the first time around, eh?
Steve in Vermont
FreeScan User
Old 12-19-2013, 5:32 PM
Fuzy_GSXR1000's Avatar
Hi Gregg welcome to the hobby!! Enjoy!!
Michael KD2CUD
Kenwood TH-F6A
GRE PSR-800
Uniden 536HP
Old 12-20-2013, 12:37 PM
thanks all seems to be gettineverything around here pretty good -one question, I have one freq.[154.8150] that just comes on as static noise only two bars on the transmission icon on the screen.would a adjusting the antenna -say a slight turn help or maybe just a better antenna this on is bargain basement stuff?
