ok to start from the beginning.
press menu, then program system, select sys type, conventional hit yes. then it said edit name press yes, see entering text. LOST
So then we went down to this part:
it says set quick key, for no quick key says hit yes.
then set start up key, for no quick key hit yes.
set number tag, to default to no number tag press yes.
set lockout, we didn't lock out any.
set hold time and delay time we did the least amount of time.
set audio AGC we turned on analog and digital.
then the P25 wait time . that is were we stopped.
You figure for this much money, they would program it for you.
Piece of crap I think...maybe we should return it. too hard to understand all this set quick key, set start up key, set number tag, what is that all about?
