Analog or Digital
N8IAA
Fortunately, GA
No. Any conventional scanner that does CTCSS/DCS-same as DPL. Will work for your county. Example: BC125AT.
Larry
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
DPL is just a sub carrier on the frequency. Any analog scanner can pick up the frequencies. If you program the DPL tone in the scanner then you won't get interference.
Businesses might use the business band and will use CTCSS or DPL because there could be someone using the same frequency. This prevents others from transmitting on their radios without the correct tone; the aforementioned CTCSS (Continuous Tone Coded Squelch System) or DPL (Digital Private Line) Sometimes called DCS (Digital Coded Squelch).
You could get away with the old Pro-26, 25-1300 MHz scanner to listen to your town. Wish my town was still analog. Alas they are digital and next year the police are going encrypted.
For more information on tones see here. http://en.wikipedia.org/wiki/Digital_Private_Line#DCS
In a digital system they don't use tones they use what is called NAC codes.
