How do I get scanner to scan system downloaded from Freeware
mw88rtc
Cortland, NY
Trying to program a Uniden BCD996XT. I've downloaded a system from Freeware, but can't get scanner to actually scan that system. I have another county already programed in scanner, which is scanning fine. (Someone else set that up for me.) I needs some advice on what to do with a system in the scanner after it's downloaded from freeware. I'm a neewbie to this, so please keep it basic.
bob550
Albany County, NY
What system did you download, and from where, RadioReference.com? Are you saying you downloaded the system into the freeware program FreeScan? If so, you'll simply need to save the FreeScan file created by the system download, and upload to the scanner once connected to your computer via the supplied cable. You should then have both the new and previously programmed systems in the 996.
mw88rtc
Cortland, NY
I've downloaded Tompkins County into freescan and the uploaded that into the scanner. But scanner does not seem to read the new system. I'm a bit confused.
N8IAA
Fortunately, GA
I understand:) I didn't have a clue until a friend sent me one of his programs, and the light came on in my head.
Go back into the program and make sure that you enabled the Quick Key for the system, and the Group Keys for the different PD's and FD's in the system. They will be at the top of the screen for each of the groups you want to monitor.
HTH,
Larry
