The meter sees the entire length of coax between it, and the antenna. If you're adding 9 feet to an existing coax, then you've made a random length of feedline between the antenna and the meter. Any measurement made that way will be random, and therefore in error.
If the TOTAL line length between the meter and the antenna is 1/2 wavelength exactly, the meter will see the same impedance as exists at the antenna end of the cable. The meter will still be in error because of line loss, but at least the complex impedance will be the same.
At CB frequencies, 9 feet is 1/4 wavelength, which will invert the impedance between the meter and the antenna, and SWR meter readings will in error.
The only accurate way to measure antenna SWR with an SWR meter is to place the meter at the antenna terminals. Anything else will introduce errors. At CB frequencies, 9 feet of cable will maximize the errors. In that case, the only time the meter will read correctly is if the antenna SWR is a perfect 1:1.
